It is currently 06 Sep 2010, 21:38
Video7Productions
 Page 2 of 3 [ 64 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: THE SWAMP DONKEY *Updated Pics*
PostPosted: 18 Jul 2010, 21:38
I can see the light at the end of the tunnel!!! The trailer is taking shape and I have gotten most of the parts ready for the final coats of paint.
Grinded down the paint and rust on the frame
After application of Rust Reformer
First Coat of Primer
Unfortunately I had to order some specialty parts online and they will not be in till later this week. Oh, and Howard I did pick up those hubs, were on sale for $25. I am also going to Oklahoma next weekend so I hope to have all of the parts painted so they have time to cure properly before assembly.
PostPosted: 19 Jul 2010, 05:27
Looking really good, replaceing the hubs is money well spent. One of those preventive moves that will pay off and you will not even know it. Great piece of mind. Good luck in OK---- have been to OKC a few times, love that place!
PostPosted: 19 Jul 2010, 08:16
Hey you're doing a great job on that trailer so far. I just picked up a little old 12ft V with an old trailer I will have to do some work on so I'll be watching your progress.
Looking good so far!
SB
My 1967 Sea King Project
PostPosted: 19 Jul 2010, 11:42
Thanks for the encouragement!
So I've decided after work I'm going to go check my trail camera on my food plots, then I'm going to start painting the trailer tonight. Some questions though, have any of you used a sponge brush when applying paint? I do have access to a sprayer but I think ill just use it on the boat. How long does rustoleum need to cure before being exposed to rain/water so that it holds up well? I don't think it will be that much of a problem because i will be gone and will have the parts in the garage but would like to know so I will be able to give it ample time. Thanks for your help and if you have any suggestions please let me know! Thanks!
PostPosted: 19 Jul 2010, 11:47
I personally would not try and brush it on. I would spray it. As for the cure time I would give it about 24 hours and even more since your going out of town you should be fine.
lowes 1032 to 1050
How to pour a solid glass transom
PostPosted: 19 Jul 2010, 17:08
Advantage of brushing is you can apply finish as thick as you want. I have fabricated many items and brushed on oil base enamel. Spraying gives a little better finish. My trailer dried in 24 hours but needed a extra couple days to fully cure because of my thick application and humity this time of year.
PostPosted: 19 Jul 2010, 23:13
So I decided to get on it and hopefully Ill be done tomorrow night. Tonight my buddy finished the welding on the frame and when I got home I drilled/counter sunk the bunks and drilled holes in the frame for the bolts.
Finished painting for the evening...
My custom winch post
Here are the leaf springs, sorry about the Picture its not great...
Tomorrow I hope to finish the painting and maybe begin to wrap the bunks in carpet. Any tips on wrapping the bunks? Oh and I did use a sponge brush today. I spent $1 for 10 of them today and they worked so much better than a brush that had cost me $5 a pop, plus I can just pitch em in the trash and not have to worry about cleaning em for a dime a piece. Ill probably spray the boat but I will be using sponge brushes on the rest of the trailer. When parts come in and Im back next week I will begin assembly and should have the trailer completed.
PostPosted: 20 Jul 2010, 12:54
coming along nicely... on your boat, if you dont want to use brushes or deal with spraying, look into those 4" high density foam rollers. i used them on my boat and really like the way it leveled out. i bought the roller and handle combo and 2 extra rollers for like 5-7 bucks at wally world!
PostPosted: 21 Jul 2010, 21:28
Hello!
Tomorrow I am leaving town and had a few questions to have answered while im gone.
-Has Anyone ever heard of or used Neomats on the floor of their boats? See Neo-Mats
-What kind of Navigation lights are you guys using? Id like to go with LEDS but dont exactly wanna pay $100 just for navigation lights.
-Anybody run a mud motor?
-Recommendation for a good boat cover during storage/travel?
I have finished painting the trailer and am going to let the paint cure while im away!
Have a good weekend!
 Post subject: THE SWAMP DONKEY ~*Need some HELP!!!!*~
PostPosted: 24 Jul 2010, 22:45
TTT
PostPosted: 25 Jul 2010, 06:14
Never used the mats so I can't offer any help.
As far as navagation lights I just use the regular lights. I mounted the recepticle up front on the deck and on the back I mounted it in the small triangle piece at the transom.
lowes 1032 to 1050
 Post subject: THE SWAMP DONKEY ~*Trailer Assembly 7/27/10 PICS*~
PostPosted: 27 Jul 2010, 21:58
So I have been bustin my butt trying to get everything ready for trailer completion. Tonight I started getting the frame put back together and Its starting to look like an actual trailer! lol Sorry in advance for the pictures they are not the best
Picked up a quick release pin for the tongue
Opposite view
Used PVC pipe to keep pressure off of the wiring conduit and plan to do the same around the winch post, They do flex a little and am thinking about filling them with liquid nails or silicone to firm them up. Any thoughts?
Again sorry for the photos, Ill be updating again withing the next few days!
PostPosted: 28 Jul 2010, 03:34
I can't tell from the pics, but if your wiring conduit is not welded to your frame, flip your u-bolt and slide the flat plate between the frame and conduit. you can always wire tie the conduit to your brackets then trim off the excess u-bolt for a cleaner look.
PostPosted: 28 Jul 2010, 04:53
really looks good and your dog is ready to go :)
PostPosted: 28 Jul 2010, 07:46
Replace the pvc with heavy wall pipe nipples or some square tubing.
PostPosted: 28 Jul 2010, 22:53
Haha yea those two are a little too jumpy for the boat, I've got a chocolate lab and he is pretty laid back and will definitely get to see quite a bit of boating action.
Today was pretty hot so I didnt really accomplish much...
But my girlfriend Shyanne got in on the action!
Finished the bunks!
She wanted to sit in it...
Because I Eyeball everything I didn't compensate for the bunk not being tall enough for the boat to clear the fenders #-o #-o #-o So after feeling a bit frustrated I decided id have to have some custom ones made and took the old ones off...
Thanks for lookin! I plan to start the winch post tomorrow and wire the trailer while im at it... If you got a suggestion or comment don't be afraid to post, Id love to hear what you guys have to say!!!!
Thanks!
 Post subject: THE SWAMP DONKEY ~*Trailer Assembly 7/29/10 PICS*~
PostPosted: 29 Jul 2010, 15:16
I was wondering why those bunks were so low, looks like you GF and pups are ready to go boating :)
 Post subject: THE SWAMP DONKEY ~*Lights and Transom!!! 7/29/10 PICS*~
PostPosted: 29 Jul 2010, 22:38
Today I got quite a bit accomplished!!!
I started out by wiring the lights and I got it done fairly early so I began to horrible transom replacement!!! :( :shock: :shock: lol
Can you say LEDS !?
To make this setup work I had to extend the ground (white to blue)
Grounded down
The tail-lights are sealed and therefore individually grounded so I extended the grounds and bolted them together.
Cutting the corner braces!
Everything just fell apart...
All cleaned up!
Okay so how do I bend this up and out of the way so I can slide in the new transom???
What I have so far...
Alright so I need some suggestions on how to bend that top cap up or info on how to work around it? I cant continue until I get some help!!!! Thanks!
PostPosted: 30 Jul 2010, 07:29
I used a pair of vicegrips with 4 or 5 inch wide jaws. They are for gutter work.
PostPosted: 30 Jul 2010, 13:12
Could you cut if off and come back with an Alum C-channel and cap it off? Not sure of the different sizes of that material but have seen people use it for Floor support over the ribs of a semi-V in other mod's.
Do not know Alum that well but would think even using large hand breaks to bend it back might compromise the structure of the material/cap...?
Nice work on the trailer BTW!
ugly boat catch cute fish
PostPosted: 30 Jul 2010, 14:28
Not sure how feasible it would be, but maybe you could make a two piece transom. Place one board on the lower half and then fit another on the top of that one by sliding it into the top bracket then pushing the bottom of it flush with the top of the lower piece.
PostPosted: 30 Jul 2010, 16:05
Instead of having some fenders made, why not just change out the 2x4's for some 4x4's. Then you would have the clearance needed to use the fenders you already have made.
As for the transom, the bottom piece of aluminum is more than likely riveted in. Why not just take the rivets out and then install the transom and then reinstall the aluminum piece. If not then making a two piece transom or bending the top aluminum up may be your only option.
lowes 1032 to 1050
PostPosted: 31 Jul 2010, 00:54
Thanks for all the comments and suggestions guys!
Today I made a run to home depot and picked up a hand seamer, plywood, glue, and vise grips to aid in my project!
I used a combo of the hand seamer and vise grips and got the top cap settled for now...
Its not too pretty, but grandad stopped by the house and he mentioned that his good friend who builds fence at his placecan weld aluminum! SCORE!
My transom in two parts, (3/4" plywood was used)
I glued and clamped the two pieces together tonight with titebond III and will probably seal it tomorrow before going to check on food plots/trail cams.
Hyzer- Thanks! I still gotta do some touch ups and finish the winch post but other than that Ill be done with it! and If I do need to replace the cap it may not be that big of a deal, I think I could just cut it flush with the back end and make sure to run bolts all the way through the new cap, wall of boat, transom boards, and out the cap, with the corner braces holding the ends.
Mixson- thought about scootin around the problem but I dont want to ever have to do this again [-o< , that was the original transom that was in it and it lasted almost 30 years. If I ever have to replace it again ill probably sell the thing, lol. so I ended up opting for the hard and dirty way.
Huntinfool-Well the amount of time and money It would take to remake the bunks, wouldnt be able to touch buying new fenders, plus the old ones were pretty much junk, When I picked up the boat the guy had to use a pry bar to bend one up so It wouldnt drag close to the tire. :shock: Im already starting to cook up ideas in my head!!! :roll: :)
PostPosted: 31 Jul 2010, 01:28
Getting that aluminum bent up out of the way is the easy part. Getting it back is a PITA. I beat on mine for an hour getting it back like it was supposed to be and its still not 100% but it was good enough to get the bolts in so I went with it. Yours seems to be in quite a bit better shape than mine is though. Mine looks like it may have had a motor ripped off of it at one time. I stained my new transom a walnut color and put three coats of spar on it. I did that little piece on the back the same way.
PostPosted: 31 Jul 2010, 01:46
yea now Im debating on whether to try and bend it back or just replace it. I found some aluminum channel that would work for $12. So If I just cut off what is there now flush with the back end, could I just bolt it all the way though and still have the craft be structurally sound? or is this a no no?
Users browsing this forum: Google [Bot], Yahoo [Bot] and 6 guests
Search for:
uchelpcenter
