It is currently 09 Sep 2010, 12:14
Buildyourownbaits
 Page 1 of 3 [ 64 posts ]  Go to page 1, 2, 3  Next
 Post subject: THE SWAMP DONKEY
PostPosted: 14 Jul 2010, 18:59
This is the wheel I used. Worked very well with paint and good with rust. If your hubs are like my old ones, they did not have stubs on them for the lug nuts. I had to run a bolt through the wheel into the hub and then the bolt would extend out the other side of the hub. Just didn't like that set up. New hub ( with studs and lug nuts ) came prepacked and new bearings inside for $30 at Northern Tool.
PostPosted: 14 Jul 2010, 19:55
Caster- Im glad you pointed that out! That would have never occurred to me. But yes I will take a look at them, I need to take the frame of the trailer apart soon anyways so I can get it prepped for primer/paint.
Howard-It looks like that would do wonders on paint/rust. Can I ask where you picked that thing up at?
PostPosted: 14 Jul 2010, 21:15
Today was extremely so not alot got done. However I did talk a friend of mine into welding for me. He attached the new safety chains to the inner tongue, tacked on the new conduit under the outer tongue and even began making me a winch post.
last coat of Rust Reformer
Conduit got a little hot
Weld is not beautiful, but will definitely hold.
PostPosted: 15 Jul 2010, 05:46
Got the wheel at Home Depot. Always good to have a friend that welds and love those boots! Like that you welded the coupler on and links to hold safety chains. Looking good in Ks.
PostPosted: 15 Jul 2010, 22:06
Spent most of the day working, so coming home to the trailer tongue still uncompleted was kind of a downer, but I got out the angle grinder and got started. Began by cutting, grinding and rounding all the sharp edges on the winch post and prepared the bow stop arms for painting. Then stopped by the local hardware store and picked up bolts to hold up the arms and some U bolts to attach it to the trailer. I also picked up some JB weld stick, Im not sure if it was a good idea or not but I did locate a few small holes towards the rear of the boat... :( But nothing major really, the largest one couldn't have been more than a 1/16" big so a little JB putty cant hurt too bad. It says that it is sand-able and paint-able so not too worried in that department. All of the tongue is primered and will probably be ready for paint tomorrow or later this weekend. I will attempt to get my bunks fabricated, cut, drilled, and sealed with Thompson's so that they will be ready for carpet and maybe even mounting if I get the trailer frame grinded and painted. Oh and Howard, thanks for the kind words bud!
 Post subject: THE SWAMP DONKEY *Updated Pics*
PostPosted: 18 Jul 2010, 21:38
I can see the light at the end of the tunnel!!! The trailer is taking shape and I have gotten most of the parts ready for the final coats of paint.
Grinded down the paint and rust on the frame
After application of Rust Reformer
First Coat of Primer
Unfortunately I had to order some specialty parts online and they will not be in till later this week. Oh, and Howard I did pick up those hubs, were on sale for $25. I am also going to Oklahoma next weekend so I hope to have all of the parts painted so they have time to cure properly before assembly.
PostPosted: 19 Jul 2010, 05:27
Looking really good, replaceing the hubs is money well spent. One of those preventive moves that will pay off and you will not even know it. Great piece of mind. Good luck in OK---- have been to OKC a few times, love that place!
PostPosted: 19 Jul 2010, 08:16
Hey you're doing a great job on that trailer so far. I just picked up a little old 12ft V with an old trailer I will have to do some work on so I'll be watching your progress.
Looking good so far!
SB
My 1967 Sea King Project
PostPosted: 19 Jul 2010, 11:42
Thanks for the encouragement!
So I've decided after work I'm going to go check my trail camera on my food plots, then I'm going to start painting the trailer tonight. Some questions though, have any of you used a sponge brush when applying paint? I do have access to a sprayer but I think ill just use it on the boat. How long does rustoleum need to cure before being exposed to rain/water so that it holds up well? I don't think it will be that much of a problem because i will be gone and will have the parts in the garage but would like to know so I will be able to give it ample time. Thanks for your help and if you have any suggestions please let me know! Thanks!
PostPosted: 19 Jul 2010, 11:47
I personally would not try and brush it on. I would spray it. As for the cure time I would give it about 24 hours and even more since your going out of town you should be fine.
lowes 1032 to 1050
How to pour a solid glass transom
PostPosted: 19 Jul 2010, 17:08
Advantage of brushing is you can apply finish as thick as you want. I have fabricated many items and brushed on oil base enamel. Spraying gives a little better finish. My trailer dried in 24 hours but needed a extra couple days to fully cure because of my thick application and humity this time of year.
PostPosted: 19 Jul 2010, 23:13
So I decided to get on it and hopefully Ill be done tomorrow night. Tonight my buddy finished the welding on the frame and when I got home I drilled/counter sunk the bunks and drilled holes in the frame for the bolts.
Finished painting for the evening...
My custom winch post
Here are the leaf springs, sorry about the Picture its not great...
Tomorrow I hope to finish the painting and maybe begin to wrap the bunks in carpet. Any tips on wrapping the bunks? Oh and I did use a sponge brush today. I spent $1 for 10 of them today and they worked so much better than a brush that had cost me $5 a pop, plus I can just pitch em in the trash and not have to worry about cleaning em for a dime a piece. Ill probably spray the boat but I will be using sponge brushes on the rest of the trailer. When parts come in and Im back next week I will begin assembly and should have the trailer completed.
PostPosted: 20 Jul 2010, 12:54
coming along nicely... on your boat, if you dont want to use brushes or deal with spraying, look into those 4" high density foam rollers. i used them on my boat and really like the way it leveled out. i bought the roller and handle combo and 2 extra rollers for like 5-7 bucks at wally world!
PostPosted: 21 Jul 2010, 21:28
Hello!
Tomorrow I am leaving town and had a few questions to have answered while im gone.
-Has Anyone ever heard of or used Neomats on the floor of their boats? See Neo-Mats
-What kind of Navigation lights are you guys using? Id like to go with LEDS but dont exactly wanna pay $100 just for navigation lights.
-Anybody run a mud motor?
-Recommendation for a good boat cover during storage/travel?
I have finished painting the trailer and am going to let the paint cure while im away!
Have a good weekend!
 Post subject: THE SWAMP DONKEY ~*Need some HELP!!!!*~
PostPosted: 24 Jul 2010, 22:45
TTT
PostPosted: 25 Jul 2010, 06:14
Never used the mats so I can't offer any help.
As far as navagation lights I just use the regular lights. I mounted the recepticle up front on the deck and on the back I mounted it in the small triangle piece at the transom.
lowes 1032 to 1050
 Post subject: THE SWAMP DONKEY ~*Trailer Assembly 7/27/10 PICS*~
PostPosted: 27 Jul 2010, 21:58
So I have been bustin my butt trying to get everything ready for trailer completion. Tonight I started getting the frame put back together and Its starting to look like an actual trailer! lol Sorry in advance for the pictures they are not the best
Picked up a quick release pin for the tongue
Opposite view
Used PVC pipe to keep pressure off of the wiring conduit and plan to do the same around the winch post, They do flex a little and am thinking about filling them with liquid nails or silicone to firm them up. Any thoughts?
Again sorry for the photos, Ill be updating again withing the next few days!
PostPosted: 28 Jul 2010, 03:34
I can't tell from the pics, but if your wiring conduit is not welded to your frame, flip your u-bolt and slide the flat plate between the frame and conduit. you can always wire tie the conduit to your brackets then trim off the excess u-bolt for a cleaner look.
PostPosted: 28 Jul 2010, 04:53
really looks good and your dog is ready to go :)
PostPosted: 28 Jul 2010, 07:46
Replace the pvc with heavy wall pipe nipples or some square tubing.
PostPosted: 28 Jul 2010, 22:53
Haha yea those two are a little too jumpy for the boat, I've got a chocolate lab and he is pretty laid back and will definitely get to see quite a bit of boating action.
Today was pretty hot so I didnt really accomplish much...
But my girlfriend Shyanne got in on the action!
Finished the bunks!
She wanted to sit in it...
Because I Eyeball everything I didn't compensate for the bunk not being tall enough for the boat to clear the fenders #-o #-o #-o So after feeling a bit frustrated I decided id have to have some custom ones made and took the old ones off...
Thanks for lookin! I plan to start the winch post tomorrow and wire the trailer while im at it... If you got a suggestion or comment don't be afraid to post, Id love to hear what you guys have to say!!!!
Thanks!
 Post subject: THE SWAMP DONKEY ~*Trailer Assembly 7/29/10 PICS*~
PostPosted: 29 Jul 2010, 15:16
I was wondering why those bunks were so low, looks like you GF and pups are ready to go boating :)
 Post subject: THE SWAMP DONKEY ~*Lights and Transom!!! 7/29/10 PICS*~
PostPosted: 29 Jul 2010, 22:38
Today I got quite a bit accomplished!!!
I started out by wiring the lights and I got it done fairly early so I began to horrible transom replacement!!! :( :shock: :shock: lol
Can you say LEDS !?
To make this setup work I had to extend the ground (white to blue)
Grounded down
The tail-lights are sealed and therefore individually grounded so I extended the grounds and bolted them together.
Cutting the corner braces!
Everything just fell apart...
All cleaned up!
Okay so how do I bend this up and out of the way so I can slide in the new transom???
What I have so far...
Alright so I need some suggestions on how to bend that top cap up or info on how to work around it? I cant continue until I get some help!!!! Thanks!
PostPosted: 30 Jul 2010, 07:29
I used a pair of vicegrips with 4 or 5 inch wide jaws. They are for gutter work.
PostPosted: 30 Jul 2010, 13:12
Could you cut if off and come back with an Alum C-channel and cap it off? Not sure of the different sizes of that material but have seen people use it for Floor support over the ribs of a semi-V in other mod's.
Do not know Alum that well but would think even using large hand breaks to bend it back might compromise the structure of the material/cap...?
Nice work on the trailer BTW!
ugly boat catch cute fish
Users browsing this forum: DocCaliz, dyurisich, Yahoo [Bot] and 7 guests
Search for:
TransducerArmor
