Derek's Tracker TX-17 rebuild
Derek
Post by Derek » 18 Jul 2011, 09:02
I did a little work on the boat saturday. I wanted to re-mount the rear battery to make it easier to access. Just slide it back so I can pick straight up through the rear hatch.
The edge of the front deck where you step down onto the floor had already begin bowing. Originally there was space under the front deck on the floor of the boat. So the Plywood was spanning about 1/2 width of the boat unsupported. See picture. Not good for my heavy ass.
To remedy this I could have braced it with aluminum angle, but then I would have had to look at it. So I moved the wall of the hatch out just shy of the end of the deck. I also added a brace under the deck running parallel with the gunnel. It is rock solid now, and I have more interior compartment space.
Image Image
I also have something else up my sleeve, or should I say, in my garage. :mrgreen: Working on the boat again later today.
Derek
Post by Derek » 19 Jul 2011, 08:48
1977 Johnson 70hp :mrgreen:
Picked it up over the weekend. Plugs looked brand new. Lower unit oil looked new. Good compression. Supposedly it had been winterized before being stored. I ran it on a stand before I bought it. It ran mint. The water coming out was as cold as the hose going in.
Finally got it mounted up yesterday. Ran all the cables, wires and fuel lines. We finally got finished and brought it to the lake. It would start but not stay running unless the high idle/start lever was pulled up. I am guessing in transportation home I dislodged a bunch of crud in the carbs. So I am going to start by cleaning them. Most likely Ill get a rebuild kit for the carbs since I will have it apart. I am also going to get an inline fuel filter. What else would you suggest looking at?
Flatbotm
Post by Flatbotm » 19 Jul 2011, 18:06
Sounds like a carb issue to me. I had one doing the same thing I ran it in the bucket 3 or 4 times for about 5 to 10 minutes. It must have been some small deposits or varnish because it cleaned itself and started idling down. How long did you run it for? Does yours have the mixture adjustment? Your boat should haul with a 70!
1993 Blue Fin Spectrum 1706 90hp Force by Mercury
2006 Crestliner x-120 w 2.5 Suzuki 4 stroke
1980 Grumman 4.6 with 35hp Johnson
1032 Lowe
2006 Alumacraft 1542 w 25hp Yamaha(SOLD)
fish2keel
Post by fish2keel » 20 Jul 2011, 00:34
Is that 70 at the head of the prop? Not saying it wont haul but im just curious! If it really is 70 at the prop its going to be boogy but i got a feeling its that at the head so its going to loose some power at the prop
Force from Above!
Derek
Post by Derek » 21 Jul 2011, 07:43
This motor would be rated at the powerhead.
Before I bought it the motor ran for a solid 20 minutes on muffs. It sat at idle for atleast 10 of those minutes. I plan to pull the carbs out and clean them today. I am not sure on the mixture adjustment on this motor. Still getting to know the old girl. Been looking for a FSM for it.
Derek
Post by Derek » 02 Aug 2011, 11:11
A little update on the motor and boat. I did pull all the carbs and cleaned them out. I replaced the fuel lines as well. After that the motor fired right up. The motor runs awesome, starts right up every time. It will run 34 by myself and 33 with 2 people. The prop is not in great shape from the previous owner, so that is significantly hurting the performance. I suspect to be in the mid 40's once I re-prop the boat.
Last weekend I made a 618 mile round trip to Maine for some fishing. The "pond" was 7.5 miles long and we did a lot of running around. I ran 17 gallons of fuel through it this weekend. No problems. I am very pleased with the motor.
Flatbotm
Post by Flatbotm » 02 Aug 2011, 11:32
That's great Derek. I was hoping it was carb related. Your boat looks like it sits real nice in the water. 40 plus mph your boat should be just barely touching the water.
1032 Lowe
Derek
Post by Derek » 02 Aug 2011, 11:44
right now, even with 2 guys, only from the seats back touches the water
Derek
Post by Derek » 11 Aug 2011, 20:38
Found a used Raker prop for the motor to replace the banged up aluminum one. Its a high performance stainless prop. Slightly larger with an inch more pitch and cupped blades. Should plane quicker and get more topend speed. Hopefully ill have it in next week.
clarego
Post by clarego » 16 Aug 2011, 09:43
same boat maybe a little restore as im going to only own a couple of years. so the aluminum capartment left of the steering column was original made for a battery >? or is it the smart thing to do im a hefty guy myself and this would solve alot of issues with the tanks and motor in the rear. mine looks avg pics to come as soon as this monsoon leaves Central PA
I used to be the One on the bank thinking to myself this sucks!
I love PETA (People Eating Tasty Animals)
http://www.tinboats.net/forum/viewtopic.php?f=3&t=21590 my 1988 tracker tx
Clarego
Derek
Post by Derek » 16 Aug 2011, 10:09
Originally both batteries were mounted in the rear, but they were also smaller batteries then I run in my boat. I moved one battery up front, thinking it would help it get on plane faster.
Currently I have mine set-up with a 12-gal tank (pass side) and a group 27 battery (drivers side) in the rear compartment. Then the group 31 battery in the pass side compartment up front. With a full tank of fuel and just me the boat sits fairly level side to side.
With another guy my size the boat will list to the pass side, but doesn't seem to make much difference at speed (-1 mph), just a larger wake.
I also have a 6 gallon fuel tank I can add into the rear compartment for when I need more fuel capacity.
Derek
Post by Derek » 18 Aug 2011, 10:14
Got the prop in yesterday. 13.5x18 Raker. Obviously I had to run to the garage and put it on so I could test it. The results are the boat is quicker but not much faster. It jumps right on plane almost instantly, but I only got 35mph out of it. I also played around with the trim a bit. I don't have power trim but I can adjust the pin on the motor. I have been running it with the motor all the way down. I tried moving it up and on the next hole the boat porpoises bad. Any ideas? I want to set it up with power trim and possibly a jack plate at some point. That will come later.
Cubman
Post by Cubman » 18 Aug 2011, 20:51
Do you have a tach on your motor? I am inclined to say your motor doesn't have enough power to pull 18" of pitch, but there is no way to tell without knowing what RPM you are running wide open.
Derek
Post by Derek » 19 Aug 2011, 08:41
I do not have a tach yet. Gauges are one of the next few things to be added to the boat. This motor came originally with a 13.25x17 aluminum prop. Stepping up to 13.5x18 does seem like a big stretch. I chose it based upon a prop shops recommendation.
clarego
Post by clarego » 19 Aug 2011, 11:25
hey bud
got some pics up
got any tips let me know
http://www.tinboats.net/forum/viewtopic ... 22#p220322
Clarego
