It is currently 24 May 2013, 23:28
Wired2fish
 Page 1 of 3 [ 37 posts ]  Go to page 1, 2, 3  Next
PostPosted: 25 Feb 2011, 18:18
Hi,
I've been lurking this site for months, and finally decided to start mods to my own boat. Last summer i picked this 1985 landau 1436 jon boat up on craigslist. since it was mid july, i did to it only what was neccesary to get myself out on the water for the rest of the summer. patched some leaks, re wired the trailer lights, etc. since spring is now on the way, i finally decided to get going on my modifications. I have come to find out that its a good seaworthy little boat after a summer of use, and still has many fishing trips left in it. but as you can see, it is about as dull and average as a jon boat gets. NOT AFTER TODAY. I have HUGE plans for this boat. I will Put a carpeted floor down, build a front casting deck, add pedestal seats, and of course, build some storage. I started today, and well, heres where im at:
File comment: i also have to say i must hand the credit for this idea to RBuffordTJ.
File comment: I started by cutting out the middle bench, i will be putting a pedestal seat in place of the bench.
PostPosted: 26 Feb 2011, 22:58
DAY 2 SO FAR: I'm pretty happy with the progress we've made so far, and whats good is we have yet to run into one of those "UH OH'S".
the pictures from todays progress are posted. like i said i have to give RBuffordTJ the credit for this idea. Except i changed it just a little bit to suit my own needs. I have Cut the bench out, added wood to the sides to keep the structure of the boat strong, ran all of the wire for my lights, and added storage underneath the cut out bench.
File comment: My storage compartments.
File comment: Next, I ran the wire for all of my lights, so i don't have to worry about wiring later.
PostPosted: 26 Feb 2011, 23:25
Great start! Do you have any plans drawn up that you could post? It always helps me visualize what is happening in any pics posted. Good luck with it!
"Crazy on a ship of fools
Turn this boat around - back to my loving ground..."
-Robert Plant
PostPosted: 26 Feb 2011, 23:26
That looks real good. Are you going to replace the wood in the transom with a full size piece? That might have been part of the reason you had some cracking of the aluminum back there.
PostPosted: 27 Feb 2011, 10:50
what i'm going to do is re-inforce the transom by putting a piece of steel on the top lip of the transom, and screwing it down so the crack disappears. i'm also going to put another piece of wood on the outside of the transom as well, to cushin the transom metal between the two peices of wood, so that the motor doesn't squeeze into the aluminum, and do anymore damage to the transom. i'll be working on the boat more today, and i'll take some pictures of the transom, and have them posted by tonight. i also do have somewhat of a plan, but it keeps getting re-adjusted a little everytime we run into something. i'll try to take a picture of my original plan, and have that posted up here tonight as well.
PostPosted: 27 Feb 2011, 21:19
day 3 complete. today, i cut out, and put down the foam underneath my floor, i also cut the floor out from plywood and got it layed down. the floor is not fastened yet, because i want to make sure that i got everything i wanted unerneath there, before i just start mindlessly screwing boards down. extremely happy with my progress in only 3 days. i'm now starting to see everything in the boat come together. i can now really get a mental image of how its all going to look when im done, and i can't wait!
File comment: the piece of steel i screwed on to the upper lip of my transom to repair a crack.
File comment: My transom
File comment: My plan-back of boat.
File comment: My plan-middle of boat.
File comment: My plan-front of boat.
PostPosted: 27 Feb 2011, 21:23
More pictures of todays work.
File comment: close up of my floor drains.
PostPosted: 06 Mar 2011, 14:06
I was really planning on getting some work done to the boat this weekend. UNTIL I woke up yesterday morning to find a giant puddle in the basement coming from my water heater. it's busted. spent the entire weekend messin around with that. no progress until further notice.
PostPosted: 20 Mar 2011, 23:22
Finally got some more progress done in the last couple weeks. i am extatic about the way this build is coming along. right now i am almost done with all the wood and ready for carpet. I can see it all now, and it's Lookin GOOD!
File comment: Sample of my storage compartments underneath the front casting deck.
File comment: The stencil for the sidewall of the casting deck.
File comment: The framework for the front casting deck.
File comment: The storage compartment added to the back seat.
PostPosted: 20 Mar 2011, 23:46
More Pictures of The Past couple weeks Progress.
File comment: My custom built battery box. this will keep the battery out of the weather, and i will be putting a lock and hasp on it to keep it from bieng stolen. this is also a great place for all of my wiring to meet up, and to put switches and fuses.
File comment: My above deck storage. This is a nice, convinient place to quickly slide small tackle boxes, in and out.
File comment: The piece of new transom wood on the outside.
File comment: Below deck Storage
PostPosted: 21 Mar 2011, 02:56
I have a question for you. Where did you get that 1" foam from? The thickest I can find at my local lowes is half inch and my foam needs to be atleast an inch and a half thick.
PostPosted: 21 Mar 2011, 11:31
dc3232: I picked the 1" foam up at my menards for $10 or $11 a sheet. I'm pretty sure I saw inch and a half there as well. It only took one sheet of foam to do my entire boat, and i still had some left over. if you can't find anything inch and a half, maybe try layering the half inch foam to make it one and a half inch. Hope this helps!
PostPosted: 21 Mar 2011, 13:26
Very nice work, looking forward to your progress
My 1237 Grumman Jon Conversion
viewtopic.php?f=21&t=12778&start=0
Harbor Freight Trailer tips:
viewtopic.php?f=49&t=13389
PostPosted: 21 Mar 2011, 14:12
Yea thats what I had in mind, except it would take like 3 or 4 sheets to do it, & the price of the sheets are about 10 bucks as well. Where did you say you got yours?
PostPosted: 21 Mar 2011, 19:46
Froggy: me too. im close to bieng done with all the woodwork, and almost ready to start carpeting.
Users browsing this forum: Abraham, Canadian, Flat Bottom, headdyb, ifish4redd, steelerfan88, wwcenturion and 66 guests
Search for:
