Daniel My Brother
6 years ago I picked up a used 2003, 1436 G3 jon boat with a 9.8hp Mercury to fish the 10hp lakes in my area. I modified the boat shortly after getting it home. Here’s what has worked for me…and a few things that didn’t.
Front Deck:
I like the layout. It fishes easy, and is about as stable as a 1436 gets. The low deck keeps my center of gravity low. I know most bass fishermen prefer a high casting deck, but a high deck on a narrow boat in a big lake scares the crap out of me.
I call this boat my convertible because the decks are removable, which makes it easy to clean, or convert for catfishing.
Middle Seat:
The Tempress hatch and liner was a good investment. A lot of choices and pretty good prices on the Tempress website.
This carpet pad protects my rods and reels.
There’s only 1 depth finder (transom mounted) on the boat so I mounted it to the middle seat. It swivels and works well here.
Rear floor.
I like that it rests directly on the ribs and is also removable. It’s ½ ply with carpet strips on the bottom where it contacts the ribs. This helps give a snug, quiet fit.
Rear bench.
½ plywood provides a sturdy base for a swivel seat mount.
Electrical.
Keeping it simple: The tolling motor plugs in to the front deck.
Wires run down the side of the boat.
The depth finder also runs off the trolling motor battery. The trolling motor breaker is in the bottom case. The depth finder fuse is in the top.
Lighting.
I’ve used these LED navigation lights for five years. I changed the AA batteries for the first time this spring. I highly recommend this simple lighting solution. The batteries last forever, there are no wires to run, and no drain on your trolling battery. I can’t say enough good things about these lights.
Bow Mount.
I use this mount from Bass Pro. The reviews on Bass Pro’s website are brutal. People HATE this mount. It’s plastic and it flexes. I’m not only used to the flexing, I appreciate it when I bump into a log or a rock. I give it a thumbs up, but it’s not for everyone.
The motor
I got lucky with this one. It's a 1984 Mercury 9.8hp that runs like new and get the boat on plane without a struggle.
The Bad Stuff
Of course not every choice was the ideal one. There are things I would do differently. I used plywood. It’s heavy and may rot, warp, buckle, and do all those things that wood does. After 6 years no problems with the front deck, but the rear bench cover was recently replaced ---it was screwed directly to the bench and water could not escape. This time I put down a bead a silicone between the bench and board to hopefully keep the water out. Time will tell.
A better choice would have been aluminum or a composite material.
I used regular staples on the carpet 6 years ago, and anyplace they came in contact with the boat there is evidence of a metal vs. metal battle. I’ve pulled out the old and replaced with stainless staples.
My wiring works fine, but I did not use marine wire. I’m told marine wiring is more flexible. I can see where that would be a help as you make changes to your setup.
Also, I purchased these rod straps from Bass Pro. They have a lifetime warranty, but are only good for about 5 years before they eventually dry out, crack, and break. I should have used Rod Savers.
Finally, a few overall shots and a couple on the water shots with my fishing buddies
Thank you for looking.
Front Deck:
Middle Seat:
Rear floor.
Rear bench.
Electrical.
Lighting.
Bow Mount.
The motor
The Bad Stuff
