I posted this under my Klamath page but I have no response and as I travel for work, my weekends are the only time I can work on the boat so I am getting a little desperate on time. My questions are:
OK, need a little help from you folks. I need to mount my battery box securely but as it is a welded boat I have no idea what I should do. Can I epoxy aluminum angles to the floor with footman loops attached to the outside? The battery has to be easily removable and the mounting must be light as the boat will do double duty as a car topper.
Also, have some 1-1/16 aluminum hinge. what are the best screws to use in ply?
