New member and new old boat project.
Boater
Post by Boater » 17 Oct 2009, 20:42
Just wanted to introduce myself and my new old boat project. Here is a 1979 Mirrorcraft with a longshaft Spirit 16hp motor. I purchased the boat motor trailer and a trolling motor for $500.00 off craigs list. I was told that the motor was junk after geting it home I spent 1/2 hour working on it and had it running. First run on the water was good no leaks and good running motor. The boat has a 16" transom and the motor is a long shaft so the first project was to modify the transom or get a jackplate, I chose to make a jack plate using 3/16" alum 2"x2" angle and some recycled wood. I spent a total of $25.00 on this 1st project and 2 1/2 hours time, I have plans to redo the complete boat, build a flat floor, casting deck in the front, paint and electronics. This is going to be a recycle reuse project as much as possiable to keep cost down to show that a nice boat can be built on a tight budget. I will keep posting as the build continues.
another of jackplate
After making jackplate
Longshaft motor on short transom
1979 Mirrocraft
jasper60103
Post by jasper60103 » 17 Oct 2009, 21:35
That looks like a real nice find. You got a working rig for $500, you can't do much better than that! Good job on getting that motor running, and the jack plate looks good and strong.
What part of Minnesota are you from? I'm just south of Mpls.
Welcome aboard and thanks for sharing. -jasper
2018 Tracker Grizzly 1648
Post by Waterwings » 17 Oct 2009, 22:23
Nice rig, and Welcome Aboard! 8)
moonfish
Post by moonfish » 18 Oct 2009, 12:53
I have a boat that style and shape. I'd mock up whatever you are planning and test it in the water before you make it glorious. You're already missing the flotation foam and the bracing of the middle bench seat. A deck even the height of the benches in the front is hard for me to walk on. Be safe
CRAPPIE_SLAYER
Post by CRAPPIE_SLAYER » 19 Oct 2009, 09:35
Good to see another MirroCraft owner. Looks like a great buy. Have fun with your build!
forced2workborn2fish
Post by forced2workborn2fish » 19 Oct 2009, 19:56
welcome!
I like this style of boat, my next will have a v-hull. $500 is a smoking deal. congrats on the new project, keep the pics coming!! =D>
Boater
Post by Boater » 28 Nov 2009, 21:54
Well it's been a while but got around to doing some work on the trailer today. The tongue was a mess, bent and short so I removed the old one welded on a new one that is 24" longer, removed the two fenders that were bolted on and different and welded on new ones. Also removed all the rust primed and painted the frame. Between coats of primer and paint the axle was disassembled, bearings, hubs, races cleaned and inspected. Everything looked good so reassembled with new seals and grease.
Boater
Post by Boater » 28 Nov 2009, 21:58
Here are some photos I will add more at as the project is completed.
azfish
Post by azfish » 28 Nov 2009, 22:11
Nice find on the boat and welcome aboard. Can't wait to see the progress you make. I too am on a budget for my build and got my boat from my work at a scrap metal recycling facility. So I really hope to keep my costs low.
Good luck and keep us posted.
danmyersmn
Post by danmyersmn » 29 Nov 2009, 10:23
Boater wrote: I chose to make a jack plate using 3/16" alum 2"x2" angle and some recycled wood.
Spend another $5.00 and use some Thompson water seal or oil based deck sealant, fiberglass resin, etc. something to seal up that wood so that your well made jackplate doesn't fall apart as the water gets waterlogged and starts to decay.
LEFT is right! The reel handle is properly oriented when it is on the left side.
Boater
Post by Boater » 29 Nov 2009, 11:47
Thats the plan, I had installed it unfinished to test how it works. Here in Minnesota the water tends to turn hard in the winter making testing impossible. I installed the jackplate and took the boat for a ride after putting 200lbs of concrete blocks, the battery, gas tank, myself, and another 180lb person in it to see how it would sit in the water and ride before spend the time and money to mod it and paint it all the way I'm planing. here is a photo of a new 14 Mirrrorcraft this is what my mod will look like, the size of the my boat is almost the same as the specs on this one.
Specknreds
Post by Specknreds » 29 Nov 2009, 15:28
Nice work on the jackplate!!
Boater
Post by Boater » 10 Apr 2010, 21:23
Well it was a busy winter and I didn't get anything done on the trailer or boat, now that it almost fishing season here I'm under the gun to get things done or at least usable for the year. I spent the afternoon working on the trailer and almost got it done. I have posted a few photos. I will have to get working on the boat in all my free time so thats ready.
wolfmjc
Post by wolfmjc » 11 Apr 2010, 00:39
that trailer looks brand new! good job...
Boater
Post by Boater » 29 Apr 2010, 00:15
Well it's been a while and my plans to have the boat ready for the MN fishing opener don't look good, however I have got some work done on it, I have most of the aluminum framing in and some of the plywood for it cut. If all goes well I will get some more time to work on it this week. Here are some photos
