It is currently 26 Mar 2017, 14:51
SwampRunner
 Page 1 of 1 [ 8 posts ]
 Post subject: leaking drain plug
PostPosted: 16 Apr 2010, 21:53
I took my boat out the other day and noticed it is leaking around the drain plug. I replaced the drain plug but it is still leaking. This is my first boat and I'm not really sure what to do here. Hoping to find some advice. Thanks
PostPosted: 16 Apr 2010, 23:31
Most plugs come with a screw type of mechanism which compresses the rubber for a good tight seal. That might help seal things.
http://www.tinboats.net/forum/viewtopic.php?f=21&t=12789
PostPosted: 16 Apr 2010, 23:47
I still have a few drops of water at the plug no matter how tight I get it.
Online
PostPosted: 17 Apr 2010, 05:27
Remove the drain plug, and dress the inside of the plug hole with some emery cloth or fine sandpaper. You say replaced the drain plug, with a new one?, or an old one you had laying around? If old one, break down and buy a new one. My thoughts. Good luck.
EAT PIE. IT’S GOOD. (AND,GOOD FOR YER SOUL)
(Chocolate Cream is Best)
I’d rather be rich than stupid. (Unfortunately, I wasn’t given a choice)
I bet one legend that keeps recurring throughout history, in every
culture, is the story of Popeye
PostPosted: 17 Apr 2010, 07:44
Yes I replaced it new one and I tighted it down.
PostPosted: 17 Apr 2010, 08:13
I had the same problem even after getting new plugs. When I filled my boat with water to check for other leaks, I figured out that water was dripping out of the center of the drainplug, not coming from around it. This was a seasense with the screw/lever that you tighten it with. I ended up buying the kind that you just screw in (no lever), got it as tight as humanly possible, and it fixed the problem. If a different type of plug doesn't fix it, you might have to just replace the whole drain tube.
My 1436 Lowe project boat- http://www.tinboats.net/forum/viewtopic.php?f=3&t=9636
PostPosted: 19 Apr 2010, 09:26
you can put some petroleum jelly around the drain plug when you put it in... this will stop most small leaks while you are out on the water
Fisher 1860AW... New Build under construction
1546 Xpress -- SOLD!!
PostPosted: 19 Apr 2010, 10:23
Is your drain tube out of round?
Paddle faster... I hear banjos
Users browsing this forum: L Kenney, lckstckn2smknbrls, RStewart, ShadyDrifter, Yahoo [Bot] and 63 guests
akmccallumco
