It is currently 22 May 2013, 10:41
View unanswered posts | View active topics
| Author |
Message |
Scott from NJ
 Posted: 02 Feb 2011, 18:56 |
Hi Guys,
I am new to this site and working on converting a Grumman 1436. The previous owner cut out most of the middle of the middle seat and had a rubber maid container for a makeshift livewell. What are my options for something a bit more permanant? I could try to find an appropriate sized rubbermaid container and drop it in and so a plywood lid or is there a place that sells semi custom livewell tubs that I could use a drain plug and install an aerator? I saw the one on here with the tub and am considering that but am open to suggestions.
Thanks Guys!
Scott
 Posted: 02 Feb 2011, 19:07 |
| Moderator |
 Scott If you get a chance, post up some pics of what you got going on. Livewells can be made from coolers, water tanks, storage bins, fiberglass, aluminum etc... All depends on your budget, needs, and what you want. I used a 30 gallon cooler for 3 years tourney fishing.
_________________ Brine Craft - 16ft Mod V
Scott from NJ
 Posted: 10 Feb 2011, 23:09 |
Hi guys,
I think I want to make my own livewell container. Can I construct a box of plywood (1/2") and encapsulate the whole thing with fiberglass resin and cloth? If so is there a special resin and cloth to get? I assume I could get it at a boating store or home depot? Does anybody have success with this?
Thanks
russ010
 Posted: 11 Feb 2011, 10:28 |
Joined: 29 Jul 2008, 20:56 Posts: 4324 Location: Canton, GA (Cherokee County)
I've seen it done before Scott... but they actually just used the plywood as a mold for the fiberglass. I don't know how they separate the fiberglass from the mold (that is one hobby I have yet to dive into), but it sure looks good when they finish. And they've got a lip around the top so that it just drops into the deck
_________________ Fisher 1860AW... New Build under construction
1546 Xpress -- SOLD!!
BaitCaster
 Posted: 11 Feb 2011, 10:52 |
Joined: 30 Mar 2010, 12:51 Posts: 1609 Location: Southern Ontario
These are pictures of the factory livewell in my Tracker 1542 with the lid removed. Basically it is an aluminum tank dropped into the middle bench with a lid and drain (I installed the aerator pump). If you know someone who can weld you could fab up the tank and lid pretty easy. Otherwise you could probably find a plastic bin or cooler that would fit the opening, cut a drain hole and install a through-hull fitting and then install an aftermarket deck hatch as the lid. Attachment:
_________________ “There’s a fine line between fishing and just standing on the shore like an idiot.” ~Stephen Wright
The Livin Large Project - viewtopic.php?f=21&t=14160
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
