It is currently 20 Jan 2017, 05:53
eaglelodgemaine
 Page 1 of 1 [ 9 posts ]
 Post subject: seat question
PostPosted: 18 Feb 2011, 10:41
hi this might sound like a silly question but , i'm going to mount seats with swivel bases on top of the benches . my question is should i mount the rear seat in the center or should i offset it ? the boat is a 12' v , i'm going to be using a transom mounted trolling motor and might upgrade to an outboard in the future . thanks for any input
PostPosted: 18 Feb 2011, 10:47
If you are not going to use a gas outboard and only have one I suggest 100% that you center it. I had mine offset originally for using my gas motor but ended up buying a second base for the center while fishing. It is amazing how much in a smaller boat a guy sitting on one ege will make things different.
PostPosted: 18 Feb 2011, 14:01
I've got mine in the center and it's never seemed to inhibit me in any way of operating the tiller. Since it's a 12 foot take it out and experiment with seating on the side while running full out to see if you're comfortable with that position before mounting the seat/seats. I've used the center seating position on both 12' and 16' jon's. My brother's got his on the side on his narrow 14', it leans just a little to much in my view with the way he's got his seats placed for two people while running full out. If you put one one the side plan out where the 2nd seat goes.
1977 16' LOWE Jon
2008 18hp 4stroke electric Nissan
1976 9.9 Evinrude 2stroke
1961 5.5 Johnson 2stroke
1993 Chevy 1500
PostPosted: 18 Feb 2011, 14:52
On my old boat (14ft Lowe Roughneck), the back seat was on the bench and off-center. I hated it....and this was on a 1448...
When my buddy was on the back, I had to lean to the opposite side up front for the boat to track properly with the bow mounted trolling motor running.
I disliked it so much that I bought a second base to install in the center...I upgraded the boat, so I never did the install...
I ran that boat for about 6 months and planned to do the upgrade this spring...a second center base would be really helpful...
Ranger Cherokee 116 - 90/65 Merc
PostPosted: 18 Feb 2011, 15:12
thanks for the replies . i'm going to be mounting 2 seats and i think i'll put them in the center of the benches
PostPosted: 18 Feb 2011, 15:56
I always place the second seat just a little off center, so that the person in front of me is not blocking my field of vision when I'm driving. From there it's easy to adjust the battery, fuel tank, gear to off set the difference.
1977 16' LOWE Jon
1993 Chevy 1500
PostPosted: 22 Feb 2011, 11:35
My boat is a 1542 and I have my seat off centre. I don't have any problems with it and, as you can see, it made room for a storage hatch in the bench.
“There’s a fine line between fishing and just standing on the shore like an idiot.” ~Stephen Wright
The Livin Large Project - viewtopic.php?f=21&t=14160
PostPosted: 23 Feb 2011, 16:47
I have to go with the Caster. Mine is off-set and I get better tiller control and line of sight with a rider up front. But I did place a second mount mid-line to use while fishing. I don't like that feeling of tiping to one side for long periods. I try to spend more time fishing then running.
PostPosted: 23 Feb 2011, 18:54
X2
If I wasn't clear...you should use two seat mounts in the back...one centered for fishing, one off center for tiller control.
Personally, if I could only have one, it would be the centered position.
Users browsing this forum: marshman, Yahoo [Bot] and 12 guests
“TheRescueStep”
