Iczer
- Joined
- Oct 27, 2010
- Messages
- 21
- Reaction score
- 0
Hi awesome site, I've been lurking on here for many months now and am addicted to this site. I think I have read over every forum post on every build and every 1 off project on these forums 100 times I've been a avid bass fisherman since I was little and always wanted a boat but never had the time to focus on one until this came along. Last fall I was blessed to receive a free boat & trailer from a family friend and am in the process of fixing it up and doing some modding. I did some digging around on the Gregor website and found the specs for my boat.
Model: H-34S (The S is for the side steering)
Length: 13'4"
Beam: 64"
Depth Bow: 26"
Depth Amid: 24"
Depth Stern: 21"
Trans Height: 15"
Hull Weight: 187lbs.
Hull Thickness: .063
Max Cap: 800lbs
Max Persons: 4
Max HP: 20 (It came with a 25hp Johnson exceeding the 20 but with side steering I believe its ok)
Some background on the boat ... the person I got it from already had a boat when he received this one some 10-15 years ago so this sat partially covered for that long out in the elements. He pulled it out at the end of summer last year and drove it around a lake to make sure it floated, motor worked, it didn't leak anywhere and he said all is well.
All the benches are crumbling to the touch and the floor was waterlogged and upon picking it up just disintegrated in my hands. The throttle control was intact but the shift was broken inside the control box. There is a plastic connector that holds the line to the lever that was broke. I picked up a new plastic piece on ebay as well as a full new control box all for less than $20.
Pics I took last fall of the boat as it looked when I brought it home:
I was able to clean it out and remove all the wood in the boat except the transom which is wedged in behind the rear supports so tight I think I would have to break the welds off to get it out (which another guy on these forums did to his Gregor and it caused some problems) so I will leave it. I took the power washer to it and blasted off about 10 years of grime and gunk.
My ideas for this boat are a low floor to replace the nightmare that was there, a bench level front deck with some hatches to store stuff out of the way, bench level rear deck with hatches in the bench and behind to cover the gas area and battery. I would like to put foam under the floor anywhere I can to compensate for what I will need to remove from the benches for storage. I would like 2 seats that I can move around from place to place on the boat with some fixed bases and 2 short posts for when a friend and I are on quiet lakes.
Based on the boat specs, motor and pics does anyone see any issues with any of those ideas?
Length: 13'4"
Beam: 64"
Depth Bow: 26"
Depth Amid: 24"
Depth Stern: 21"
Trans Height: 15"
Max Cap: 800lbs
Max Persons: 4
