It is currently 21 May 2013, 04:10
View unanswered posts | View active topics
| Author |
Message |
kcnokc
 Posted: 28 May 2011, 22:47 |
I have a 17 ft Lowe, it has always seemed to set very low in the stern. A friend of mine said he added 100 lbs to the front of his Tracker and it helped it handle a lot better in the wind and was easier to anchor because the bow didnt catch as much wind. Do yall think thats feasible?
linehand
 Posted: 29 May 2011, 01:35 |
Joined: 13 Mar 2011, 21:34 Posts: 278 Location: S.W. Michigan
I would redistribute the weight to make it even in the water. Battery and fuel cell to the front. Kind of like my paycheck
_________________ my toolbox contains: zip ties, duct tape, big hammer, and band aids.
kcnokc
 Posted: 29 May 2011, 12:25 |
It's a 1978 Jon boat.  You can see the stain from the water line. see what i mean? yes I have 2 batteries and 2 6gal fuel tanks but I hardly ever fill them completely. I really dont want to move it all to the front because I would have to modify the front deck to get it all up there and make it accessible. I'm thinking about putting weight up in the front to change the point of balance in the boat, move it forward. I normally anchor and catfish out of this boat.
nomowork
 Posted: 30 May 2011, 00:38 |
Joined: 20 May 2011, 00:42 Posts: 1059 Location: The wacky west coast
Not on a boat, but I once took my double seated kayak out alone fishing without my GF. I told her that the front sat too high out of the water without her there so I added about 30 pounds of rocks on the front seat to stabilize it. She wasn't too mad.
_________________ HAPPILY UNEMPLOYED
flatboat
 Posted: 30 May 2011, 16:33 |
Joined: 03 Apr 2011, 07:52 Posts: 232 Location: illinois & louisiana
are you having issues, does it porpoise . if not i wouldnt worry about it you kinda want it heavy in the back , it will run better if the weight is back there . i don't think i would add weight. most of the time i fish in the front so it evens mine out .
seif5034
 Posted: 30 May 2011, 21:13 |
Joined: 09 Apr 2008, 17:27 Posts: 70 Location: wakefield, ks
flatboat wrote: are you having issues, does it porpoise . if not i wouldnt worry about it you kinda want it heavy in the back , it will run better if the weight is back there . i don't think i would add weight. most of the time i fish in the front so it evens mine out . Good point. considering most fisherman stand/sit at the Bow while working the lures. that's a heafty chunk of weight distribution right there.
kcnokc
 Posted: 01 Jun 2011, 11:48 |
Don't have a problem with porpoising at all. I really noticed the benifit of having more weight in the front when I had my wife sit up front going through a shallow area. I have a problem anchoring in current or wind because when I bait fish I normally have to fish off the back of the boat and anchor facing the wind or current. With the bow up in the air like that it makes the boat sway more. I may add 50 lbs at a time to see if it helps, I know ultimately I should move the batteries up front but I'm thinking about getting a pontoon boat and dont want to make a bunch of mods and then sell the boat.
Thanks for the input everyone, i appreciate it.
FuzzyGrub
 Posted: 01 Jun 2011, 12:24 |
To me, it is a sin to add any non-functional weight,  but understand your motivation and short-term need. Even so, I will make another run at redistribution or a portion of. Take one of you 6 gal portable tanks and move it to the furthest forward, on floor, or if that is a lower deck. Latch it down. Since you are not in the bow, the above deck placement should not be in the way. This will transfer about 37lbs from the stearn to the bow, and would be the near equivelent of adding dead weight of 74lbs. This can be easily reverted back when fishing with two people, and when you sell it. You would also have to transfer tank back once primary is used up, but it sounds like your trips might not even require it. You can extend the primer bulb hose length real easy and for these solo trips, shouldn't be an issue with above floor hose. If on these specific fishing trips you are not using the trolling motor, consider something similiar for that battery, as well. That would be an even larger weight transfer, but if you are in rough water, might not be the best thing for the battery. If you are able to do both of those, I doub't you would need any more additional weight. Also, you have everything you need to do a test asap. John
_________________ Project: 1995 1648 DMI/1998 25HP Merc: 1967 Starcraft 14' Mariner V/1987 Nissan 40C 1997 Bayliner Capri 2050/350 4brl Vortec Mercruiser JohnS http://www.joefishin.com/
KMixson
 Posted: 01 Jun 2011, 16:02 |
Joined: 25 Apr 2008, 16:54 Posts: 1129 Location: North Charleston S.C.
You could try to move batteries, tackle boxes, and gear forward if you could.
lbursell
 Posted: 01 Jun 2011, 17:17 |
Joined: 18 Aug 2010, 06:33 Posts: 388 Location: Bonham, Texas
kcnokc wrote: I really noticed the benifit of having more weight in the front when I had my wife sit up front .... In writing this, you Sir, are a braver man than I am. I salute you.
_________________ Resurrecting A 1652 MonArk viewtopic.php?f=21&t=16589
I've grown used to doing stupid things, I just try not to have witnesses.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
