It is currently 25 Feb 2017, 00:32
mud-skipper
 Page 1 of 3 [ 34 posts ]  Go to page 1, 2, 3  Next
PostPosted: 05 Mar 2008, 16:23
Hi Guys,
I wanted to install a fish finder on my old 1957 14’ V-bottom aluminum boat, but I didn’t want to drill any holes in the hull because the hull is in excellence shape.
So what I did was make a mounting bracket out of ¾" plywood and mount it on the boat using one of the two oarlocks.
I then mounted the fish finder display head onto the mounting bracket.
After quite a bit of pondering about how to mount the fish finder’s transducer, I decided to use two of the bolts on the transom’s rear plywood to hold a bracket made of ¾" plywood.
Not wanting to cut a hole in the transom for the fish finder’s transducer’s cord, I installed the transducer on the plywood bracket and ran the cord over the top of the transom. Not too pretty, but it works!
In the above photo you can see the ¾" spacer that I epoxied onto the lower backside of the transducer’s mounting bracket.
Simple installation without any new holes!
Bill
 Post subject:
PostPosted: 05 Mar 2008, 16:28
Bill,
Welcome aboard and thank you for joining.
You did some awesome work. Allot of people hate putting holes in their boats and this is a great way around it.
Thanks for posting.
This Site is Rated PG, No Politics, No Porn, No Bashing allowed!
 Post subject:
PostPosted: 05 Mar 2008, 16:30
That's nice work, and a great idea using the oarlock! Set yourself up a photo gallery and post some pics of the boat..............we like pics :)
Welcome Aboard! :)
 Post subject:
PostPosted: 05 Mar 2008, 19:30
Welcome! What model and year boat is that? I have never seen wood on the outside of an aluminum boat transom. Was that original?
 Post subject:
PostPosted: 05 Mar 2008, 21:02
I went with one of these as opposed to a wood option as I too was too chicken to drill a hole in my transome below the water line. I like that it should last me as long as the boat without worry and is an easy change from boat to boat if needed.
 Post subject:
PostPosted: 05 Mar 2008, 22:30
Ouachita wrote:
\ I have never seen wood on the outside of an aluminum boat transom. Was that original?
I have had boats from the 50s that had wood on the outside of the transom, and boats from 1997 that had wood on the outside. That style of transom, was very common throughout the 50s and 60s. I would bet that the inside of the transom has wood too. And, being out in the open, many think it would rot real quickly, but it doesn't. It drains off, and leaves no place for moisture to collect, and thereby rot the wood. And, if it did need changing, you pull 6 easy to get to bolts and it comes right off. Now, if many companies still did this, especially on welded boats, it would make lotsa things a whole lot easier.
 Post subject:
PostPosted: 05 Mar 2008, 22:33
Quachita wrote:
"Welcome! What model and year boat is that? I have never seen wood on the outside of an aluminum boat transom. Was that original?"
Quachita, the boat is a 1958 Richline Model Challenger that was made in Arkansas during the 1950's and 1960's.
Overall length: 14 ft.
Gunwale length: 14" 11"
Beam: 60"
Max depth: 23"
weight: 205 lb.
Gauge aluminum: .064
Maz. HP: 35
This is the first aluminum boat that I also have seen with wood on the outside of the transom. As far as I have been able to determine it is original.
It is a stoutly built boat with hundreds being sold to boat rental places during that period.
Bill
 Post subject:
PostPosted: 05 Mar 2008, 22:42
bAcKpAiN wrote:
"I went with one of these as opposed to a wood option as I too was too chicken to drill a hole in my transome below the water line. I like that it should last me as long as the boat without worry and is an easy change from boat to boat if needed."
baAcKpAiN, that is really a great looking product! If I had known about it I might not have built a wooden arm!
Oh, who am I kidding? I'm very cheap!! :roll:
Thanks,
Bill
 Post subject:
PostPosted: 05 Mar 2008, 23:02
bassboy, you are certainly right about it being easier to make repairs or replace the transom if all aluminum boats were built that way.
My boat's transom does have only a single sheet of aluminum sandwiched between a front and rear sheet of plywood! I don't know if all of the Richline boats were made like that or not.
It is a nice boat for my limited use. But, of course, l'd like to have a longer and wider Jon boat! But, not likely in this lifetime! :lol:
Bill
 Post subject:
PostPosted: 05 Mar 2008, 23:56
Bill, That's a nice boat and really clean. Nice work. I have a 65 richline and it has the wood on the outside to. Does yours have the red and green lights on seperate sides on the front of the boat (reminds me of eyes)? I'm glad this came up because I'm fixing to install my fishfinder. Will have to check out the bracket that bAcKpAiN posted.
 Post subject:
PostPosted: 06 Mar 2008, 10:08
By the way Bill, welcome to the forums! Thanks for sharing your boat with us. I never get tired of seeing pictures of fish and boats!
 Post subject:
PostPosted: 06 Mar 2008, 11:11
Hi Switchback,
I'm glad to read that you also have a Richline! No doubt there are lots of the boats still in use, but they are not as well known as other makes.
The two red and green bow lights on my boat has been replaced by a single red/green light, but the holes were still visible when I bought the boat. I have since filled in the holes with J.B. Weld
There is a yahoo group for Richline boat owners. It has only 4 members and zero activity...but there are some old Richline brochures posted that are interesting. Maybe you will join and increase the membership by 20%, plus post a photo of your boat? :lol:
http://groups.yahoo.com/group/Richline_53/?yguid=472415
Bill
 Post subject:
PostPosted: 06 Mar 2008, 11:14
Old Bill wrote:
Hi Switchback,
Bill
Bill,
If you can get those guys to join here, I will make a forum just for Richline boats......No big deal either way. We are always evolving and trying to make it better here. :D
PostPosted: 14 Jul 2008, 19:49
thank you for this idea old bill!.. im doing the same for my fish finder and the other side i will use for a my rod holder!! thanks hope you dont mind me using your idea for my jon!
:oops: :oops: :) :) :) ill post when im done with the project!!
http://www.facebook.com/tcmdoc
Tampa, fl
IN THE HUNT LOOKING FOR A JON!!
PostPosted: 14 Jul 2008, 19:52
Kemical, I'm pleased you think the idea is worth doing!
Good luck,
Old Bill
To be happy...one must act happy!
Users browsing this forum: Baidu [Spider], Bing [Bot], Yahoo [Bot] and 58 guests
FishonFabrications
