It is currently 24 Feb 2017, 08:33
Wired2fish
 Page 1 of 2 [ 21 posts ]  Go to page 1, 2  Next
 Post subject: Leaking Starcraft
PostPosted: 20 Jul 2012, 17:23
I have a 1979 Starcraft Mariner 180 center console that had developed a serious leak. Last winter we stripped it down to the bare hull replaced the transom re-riveted all bad rivets dropped the hull in the water observed no leaks replaced the decking steering seats etc dropped it in the water and it still leaks. Not as much but I have no idea where its coming in. Bilge pump kicks on about once an hour and pumps 2-3 gallons so its not a tiny leak. Anyone have any idea where the water could be coming in?
PostPosted: 20 Jul 2012, 19:28
Take the hose and fill the boat with an inch or two of water and look under it while it sits on the trailer. If you don't see anything lower the bow and repeat. :mrgreen:
 Post subject: Re: Leaking Starcraft
PostPosted: 20 Jul 2012, 20:27
Alcoa aluminum gutter seal.
It's the Best stuff I've ever used. Once you fill up your boat with water and mark out your holes.
PostPosted: 21 Jul 2012, 00:11
Well either you have a leaky rivet, a new hole, leaky drain plug or a leaky through hull fitting(bait or livewell). Probably nothing you didn't already know. :D Sorry, wish I could be more help.
15ft Klamath Advantage, 25hp Honda Tiller, Minn Kota 55 Ipilot up front, Minn Kota 55 on the transom, Cannon Downriggers, VHF radio, 2 deep cycle batteries and switch, lowrance M68c, Nice custom bimini top and more fishing gear than I really need.
Locksmith in Fremont
PostPosted: 21 Jul 2012, 01:03
Have you tried bunking your rivets?
Flat metal plate on the bottom of the rivet and have someone hit the top of the rivet with a hammer
PostPosted: 21 Jul 2012, 09:50
Couple people who know their stuff suggested bunking the keel rivets and using Gluvit liberally on the inside of the hull. Anybody familiar with that stuff? Worst part is just replaced the entire floor and carpet so pulling that back up doesn't make me happy but I want to be able to leave the boat in it's slip and not worry about it.
PostPosted: 21 Jul 2012, 09:56
Alcoa gutter seal? Stupid question. Do you apply inside the hull or outside? If it will work on the outside would make a great temp fix.
PostPosted: 21 Jul 2012, 10:29
Do a leak test like 6's described, a few inches of water in the bilge and look for water dripping under the boat. You may just have a screw hole you missed during your past resto.
Gluvit and Coat-it are some pretty good stuff, but it has to be applied to the inside of the hull.
Did you carpet over your deck fasteners? Never do that on a tinny, wrap all of your deck pieces with carpet and then install them on the boat with the fasteners exposed. This way you can remove part or all of your decking without messing up your carpet to make below deck repairs and inspections.
Rum, wenches, and song... just another day on my boat.
PostPosted: 21 Jul 2012, 21:41
If you wanted a quick fix it would work fine on the outside if you used the bottle to squeeze it into the hole, the reason it works so good on Jon boats is that it has aluminum powder in the sealant allowing it to get a much better seal and it stays longer.
I would still later on go inside and use it to seal the inside also.
PostPosted: 21 Jul 2012, 21:48
I second using gutter sealant, I personally use the grey gutter seal made by OSI
New boat: Grizzly 1648 Mercury 40/30 Jet
Eldocraft 1436 '87 Evinrude 8
Grizzly 1648 Jet build:
http://www.tinboats.net/forum/viewtopic.php?f=21&t=31108&p=319525#p319525
PostPosted: 21 Jul 2012, 21:56
Just a warning on Alcoa is to make sure if you are putting it on the outside to not use too much because If you decide to take it off it's not coming off easy, it's made to stay forever, and you always make sure the metal is above 40* degrees and that makes it wick right into the hole
PostPosted: 22 Jul 2012, 18:56
Thanks for all the help. The season here is over Sept 30 so will go with the alcoa for a temp fix and pull the floor the off season.
PostPosted: 22 Jul 2012, 19:11
You can use it for a permanent fix when you pull the carpet and put it in from the top, I'll post an instructable as soon as I get my new tube of Alcoa in the mail
I learned about it from using it with my dad when I was a kid, they're is gutters from early 70's that still have a good seal from Alcoa, it's great stuff
PostPosted: 22 Jul 2012, 19:45
If it's that good I'll give it a whirl. I have a trailer with a boat slip on a lake about 175 miles from my house and I want to be able to turn my back on the boat without worrying about it.
PostPosted: 22 Jul 2012, 19:55
I'll post an instructable on it when I get it in the mail
Users browsing this forum: Google [Bot], Google Adsense [Bot], ShadyDrifter, surfman and 36 guests
Wired2fish
