Old Boat
StarCraftHans
Hello All,
I just joined today and after looking though some of the posts I believe I came to the right place. I just picked up an older Starcraft 14' V and the id tag is barely legible. I can make out that it is a Starcraft 14' Super Duty and I have the serial number which is a 6 digit number starting with 57.
So starting out I am looking for help to determine the year of my boat. Not sure if that really makes a difference but it would be nice to know.
2nd, you already answered this question. Can I take out the metal boxes under the bench seats that hold the old white Styrofoam. It sounds like that is a bad idea. I will probably replace it with the pink or blue stuff. I was hoping to leave these boxes out instead of sanding them down and repainting them.
I want to replace the actual benches because of rot and cracks. Not sure what kind of wood to use to span the 52" space. There is a 3/4" bracket I have to slide the wood back in to and the bracket is riveted to the side. Sounds like painting is the best option based on the group here.
Other items I want to deal with are: replacing the plywood on the transom, finding a new drain plug or replacing the whole unit. I found 2 sizes at our local Fleet Farm but I need one that is in the middle of these. Kinda sounds like a story here, you know with the bears...
I am taking out the 2 sets of oar brackets along with the 1-1/2 oars and replacing with new.
I am mounting a plastic ? mounting board on the transom to mount my transducer to, how do I make sure to not get any leaks doing this?
There was an old anchor bracket mounted on the bow that I took off, not using, and found that it was holding part of the bow cap together. Sorry about my terminology here, please correct me as needed. So where do I find a replacement for that? I don't have the dims right now.
Then I want to paint the floor and also the top portion of the outside above the waterline. Looking for help on how to remove, prep and finish both. I was thinking of using bed liner material for the floor but I can't find it in anything but black. So maybe just mixing in some silica sand in whatever paint I get.
I'll come back back in a couple of days to check on all the good advice I feel is coming and thank you for it in advance.
StarCraft Hans
Looks like I used the wrong forum, so I copied it over here
Over on iboats there is a listing of StarCraft serial numbers. As far as the seats, removing floatation is never a good idea. If you've never swamped a boat you are fortunate I never thought I would either until I hit a wave at a bad angle while trying to start a motor that was not cooperating. Long story short, leave the floatation in, hopefully you'll never be glad you have it. I did my seats in 1" rough pine planned down to 7/8. It just fit the brackets. Stained and coated with 3 coats of helmsmen spar urethane. The floatation boxes add rigidity to the seats. Here is a link to the refresh I did on a beat up old 12 footer.
https://www.tinboats.net/forum/viewtopic.php?f=21&t=44152
SCHans, welcome to TB. We all enjoy looking at pic's. Put some up if you get a chance.
I am going to admit to a personal bias here, but I do not like to see bed liner used on a boat. I think what fun future maintenance is going to be when someone has to remove that stuff. Also agree with you about the black liner not being a great color for the inside. Anyway, that is just me. YMMV.
Thanks for sharing you story WM, the boat looks great.
I agree with you LDUBS, I would hate to tackle that job. I will see if I can figure out how to add some pics
OK, I'm probably not the best guy to try to explain this but here goes
How to add a photo that is saved on your computer:
From the Post a reply screen, click on the "Attachments" button at the bottom of the screen.
Then click on the "Add Files" button:
Select the pic you want to post. Then position the curser where you wan the pic to be in the dialog box and then click the "Place Inline" button:
To add more photos just keep clicking on the "Add Files" button. That is what I did for this post.
Hope this works.
Looks like some good bones. I used a piece of 2x10 for my transom. That little bit of plywood isn't doing anything for strength back there.
