It is currently 21 May 2013, 15:37
View unanswered posts | View active topics
| Author |
Message |
acwd
 Posted: 15 Jul 2012, 07:37 |
Joined: 11 Jan 2012, 10:26 Posts: 183 Location: Albion, IL
I bought a boat, trailer and a couple of motors yesterday. Anyway on of them is a 20 hp Merc. The guy said he couldnt get it to pee. He put a new impeller in it and still no pee and the shifter was messed up. So I got it home and dropped the lower unit. Checked everything out. The seal that the water tube goes in was in there wrong so I fixed that. Blew air thru the tube into the block and the tell tale tube to make sure that there was no blockage. Put the thing in in a barrel fired her off. No pee. So out of the barrel and back on the boat. Put the muffs on it. Water ran out the exhaust when it was running but no pee. I let it sit and run for a minute or to then it started to pee. So I let it run a few minutes like that. Back in the barrel. Fired up ran for 15 to 20 seconds no pee then it started to pee and quit. So I blew air back thru the pee hole. And it started to pee regularly. Ok the question is how long should it take to start to pee? Its taking about 15 to 20 seconds. Normal? or does it still have some junk pieces of the old impeller floating around in the block? And how would I get them all out? Access cover? All of this is between the idle and start position on the handle.
Thanks Steve
Gramps50
 Posted: 16 Jul 2012, 13:17 |
Joined: 16 Feb 2012, 18:22 Posts: 858 Location: Murphy, Missouri
When I replaced the impeller in my 20 hp a while back. There was a piece of old impeller wedged in to the top of the pump housing where the water tune goes. My impeller was not missing any blades so it was off another one. Wasn't having the problem what you were having in fact I was chasing oil in the lower unit when I found my bad impeller.
_________________ --- Gramps 1985 1651 Polar Kraft 20 hp Mercury HB 597 ci HD DI
JMichael
 Posted: 16 Jul 2012, 19:35 |
Joined: 19 Jan 2012, 07:44 Posts: 1452 Location: Northeast Arkansas
I've got a 75 model 20hp that I just put a new impeller in this spring. It takes about 4-5 seconds from initial startup before it starts to pee. So I'd say either your pump is a little weak or you still have some sort of blockage somewhere in the system. I'd pull the top off the pump housing and inspect the impeller, housing, plate, etc for any problems as well as checking out the water flow passages.
_________________ Mike My boat mod viewtopic.php?f=21&t=23359
acwd
 Posted: 16 Jul 2012, 22:49 |
brand new impeller he even showed the package that it was in. The thing looks brand new. The only thing I can think is the gasket between the faceplate and the top of the pump isnt sealing good. Someone used a piece of rubber and made one so I cut one out of gasket material so I could a least try it out before I buy an whole brand new pump. I believe the pump thats in there is where the problem lies. The only place I didnt check was the water intake. there might be something in there. Started it this morning after sitting in the barrel for a day it did seem to pee quicker than before maybe 5 to 10 seconds.
Steve
JMichael
 Posted: 17 Jul 2012, 18:49 |
I'm no OB mechanic, but I would think that if you increased the thickness of the gasket between the upper and lower halves of the pump housing, that would open up some space above/below the fins of the impeller and allow water to flow around the impeller, making it less efficient. I'd also check to make sure the water tube fits snugly where it connects to the water pump so it can't be losing any water pressure there.
acwd
 Posted: 18 Jul 2012, 08:21 |
The gasket material that I used was thinner than (about half of the thickness) the one that was in there. The seals where the water tube go in seem to fit the tube tight. I will have to try hooking up the hose to the tube and see if anything comes out. And check the passage below the water pump. Order a new gasket and seal kit if I can get just those parts and try that if I cant get just those parts, a whole new pump.
Steve
Gramps50
 Posted: 18 Jul 2012, 12:59 |
Captain Ahab wrote: Order a new (correct) gasket +1
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
