I'm going to be placing a bilge pump in my Sea Nymph 14R and I I think I know where I'm placing it but would like to hear opinions on my placement. I'm thinking of putting it here:
Might want to put it on the other side of the transom support - yes it will be set a smidge higher, but it will have the transom support to protect it should the gas tank shift around while trailering the boat.
I like the idea of raising it a bit and good call on the gas tank. I plan on having storage on either side of each transom support. Decisions, decisions. Thanks for the input everyone!
I'd put it where it had a little clearance on all sides (at least enough to get your fingers in to) in order to be able clean out any leaves or other debris that gets in there.
I plan on painting the bilge area with truck bed liner after I've used it a few times and its gotten rinsed out. The boat sat with leaves rotting in it for years, and the bottom is kinda gungy. waiting until after I take it out a few times and it gets rinsed out well before I paint it.
