Seth
Is it ok to remove the back bench seat IF you replace the area with a couple of ribs to sure up the overal boat structure?
Yep. The back one isn't as important as the middle one, unless you are looking at rougher water/higher horsepower.Seth said:Is it ok to remove the back bench seat IF you replace the area with a couple of ribs to sure up the overal boat structure?
Hanr3 said:Really depends on how the boat was made. My 14' has a reinforced top rail and side rails (spray rails). Pretty solid set up.
