I'll get a pic posted soon. Right now it's flipped over on saw horses.What is on the inside of the boat where the patch? Is there any visible damage?
Nope not made up my mind.Pretty obvious he’s made up his mind to just glass over it. Interested to see how it proceeds as well.
You get the Nostradamus award!That keel sure looks "attached" to me. My guess is that someone probably dropped it on a rock and there is a hole in the keel (but not in the boat). Not leaking as the keel is not part of the bottom of boat. Prior owner probably saw hole and "thought" it needed to be sealed. Who knows (till you get that fiberglass off) it could just be the drain hole in the keel which is designed to be there to get water out of it. I've had people see water coming out of it when they pull out and think it needs to be sealed, but it doesn't.
What about brazing?I'd probably just haul it off to a welder. That's not a bad repair at all, welding in a filler strip would take an hour or so at most. Couple hundred bucks and it's fixed forever.
I don't have much faith in epoxies. They can work exceptionally well as temporary or "in a pinch" fixes, but not as a permanent repair.
About the only issue to resolve on the Sears boat I recently bought is this fiberglass patch on the stern. Thankfully it did not cause a leak. Well…yet.
Suggests for how to seal the raised part back down are appreciated
Remove all the fiberglass and see what they were trying to repair. Then you have a good idea what to do next . Get it welded, JB weld , steel putty in a tube etc . Use something designed for metal . Not fiberglass. Good luck .
What about brazing?
Never saw brazed aluminum hold up for long, I would consider good epoxy over brazing..but that is my opinionWhat about brazing?
I'm leaning towards a good epoxy. There are many options on the market.Never saw brazed aluminum hold up for long, I would consider good epoxy over brazing..but that is my opinion
It was pealing up on the edge, and it didn't take much effort for me to pop it off like a dried up scab!Based on my personal skill set, I would likely go the same way.
Looks like the previous fiberglass patch just popped right off. That was a good thing.
Talk to a welder first.I'm leaning towards a good epoxy. There are many options on the market.
