1248 Semi V build/restoration
<blockquote data-quote="Johnny" data-source="post: 375849" data-attributes="member: 13599"><p>If it is stamped metal, with recessed lettering, remove the plate carefully</p><p>by drilling out the rivets.</p><p>If you can get it perfectly flat with a rubber mallet and some gentle massaging,</p><p>you can wet sand it on a flat surface starting with 220 grit up to maybe 360 or 400.</p><p>then, you will have a nice shiny aluminum plate with paint in the recessed parts.</p><p></p><p>You can also order a nice looking replacement for it online. About 30 bucks.</p><p>Just search for BOAT CAPACITY PLATE.</p></blockquote><p></p>
[QUOTE="Johnny, post: 375849, member: 13599"] If it is stamped metal, with recessed lettering, remove the plate carefully by drilling out the rivets. If you can get it perfectly flat with a rubber mallet and some gentle massaging, you can wet sand it on a flat surface starting with 220 grit up to maybe 360 or 400. then, you will have a nice shiny aluminum plate with paint in the recessed parts. You can also order a nice looking replacement for it online. About 30 bucks. Just search for BOAT CAPACITY PLATE. [/QUOTE]
