Motors
1955 Evinrude 7.5 Fleetwin - busted pull cord
<blockquote data-quote="Pappy" data-source="post: 466779" data-attributes="member: 3278"><p><span style="font-size: 18px">Remove the handle. You will not find a handle/cord "assembly". </span></p><p><span style="font-size: 18px">The rope has to be a specific length, no shorter. The rewind spool has to be wound a specific number of turns before the rope is added and the spool is allowed to retract. If you install a rope that is too short and the rope comes to the end before your arm does...parts break. </span></p><p><span style="font-size: 18px">I do not have those figures in front of me but you should be able to look them up. </span></p><p><span style="font-size: 18px">Hoping you are running that engine on a 16:1 fuel oil mixture. Certainly nothing less than 20:1 as that particular horsepower had a nasty tendency to lose #1 rod if run on a lean oil mix. </span></p><p><span style="font-size: 18px"></span></p></blockquote><p></p>
[QUOTE="Pappy, post: 466779, member: 3278"] [size=5]Remove the handle. You will not find a handle/cord "assembly". The rope has to be a specific length, no shorter. The rewind spool has to be wound a specific number of turns before the rope is added and the spool is allowed to retract. If you install a rope that is too short and the rope comes to the end before your arm does...parts break. I do not have those figures in front of me but you should be able to look them up. Hoping you are running that engine on a 16:1 fuel oil mixture. Certainly nothing less than 20:1 as that particular horsepower had a nasty tendency to lose #1 rod if run on a lean oil mix. [/size] [/QUOTE]
Motors
