1995 Grumman 1784 TC Complete Rebuild
<blockquote data-quote="dearl" data-source="post: 413745" data-attributes="member: 1760"><p>Moving right along...Got all the corrosion removed and pits filled under stringers 5-8, Got the transom pits filled, also got the splash well sealed and reassembled. Still need to fair the splash well out a little from the welding, then its getting ZC primed. Going to spend this week re-installing these stringers, pulling the last 4 stringers, repeating the corrosion removal process, Re-install those, and get the unneeded transom skin holes welded, then install the new transom wood. I want to have the boat flipped by the end of the month prepping the bottom for paint.</p><p></p><p>[ATTACH=full]85212[/ATTACH]</p><p></p><p>[ATTACH=full]85213[/ATTACH]</p><p></p><p>[ATTACH=full]85214[/ATTACH]</p><p></p><p>[ATTACH=full]85215[/ATTACH]</p></blockquote><p></p>
[QUOTE="dearl, post: 413745, member: 1760"] Moving right along...Got all the corrosion removed and pits filled under stringers 5-8, Got the transom pits filled, also got the splash well sealed and reassembled. Still need to fair the splash well out a little from the welding, then its getting ZC primed. Going to spend this week re-installing these stringers, pulling the last 4 stringers, repeating the corrosion removal process, Re-install those, and get the unneeded transom skin holes welded, then install the new transom wood. I want to have the boat flipped by the end of the month prepping the bottom for paint. [ATTACH type="full" alt="IMG_2651.JPG"]85212._xfImport[/ATTACH] [ATTACH type="full" alt="IMG_2652.JPG"]85213._xfImport[/ATTACH] [ATTACH type="full" alt="IMG_2653.JPG"]85214._xfImport[/ATTACH] [ATTACH type="full" alt="IMG_2654.JPG"]85215._xfImport[/ATTACH] [/QUOTE]
