2072 SeaArk mods
<blockquote data-quote="dearl" data-source="post: 426599" data-attributes="member: 1760"><p>Consoles mounted, new 12v fuse block is in and hot. Had to put a couple of braces in the live well to support the new lid and hatch. The PO had cut access panels In the old bench and screwed it up. I opt to lay In a new .125 bench lid over the live well. New 3 bank on board charger arrived, going to get it installed tonight hopefully. Still have the live well plumbing to do and finalize the wiring but she's coming together. All goes well and the rest of the material comes In this week, next post will be from the water on a test run.</p><p></p><p>80 gallon live well bracing</p><p>[ATTACH=full]89249[/ATTACH]</p><p></p><p>Console mounted with battery storage</p><p>[ATTACH=full]89250[/ATTACH]</p><p></p><p>New 12 volt fuse block</p><p>[ATTACH=full]89257[/ATTACH]</p><p></p><p>24 volt trolling motor batteries inside</p><p>[ATTACH=full]89251[/ATTACH]</p><p></p><p>new 3 bank onboard charger</p><p>[ATTACH=full]89252[/ATTACH]</p><p></p><p>Some outside shots</p><p>[ATTACH=full]89253[/ATTACH]</p><p></p><p>[ATTACH=full]89254[/ATTACH]</p><p></p><p>[ATTACH=full]89255[/ATTACH]</p><p></p><p>[ATTACH=full]89256[/ATTACH]</p></blockquote><p></p>
[QUOTE="dearl, post: 426599, member: 1760"] Consoles mounted, new 12v fuse block is in and hot. Had to put a couple of braces in the live well to support the new lid and hatch. The PO had cut access panels In the old bench and screwed it up. I opt to lay In a new .125 bench lid over the live well. New 3 bank on board charger arrived, going to get it installed tonight hopefully. Still have the live well plumbing to do and finalize the wiring but she's coming together. All goes well and the rest of the material comes In this week, next post will be from the water on a test run. 80 gallon live well bracing [ATTACH type="full" alt="IMG_0291.JPG"]89249._xfImport[/ATTACH] Console mounted with battery storage [ATTACH type="full" alt="IMG_0289.JPG"]89250._xfImport[/ATTACH] New 12 volt fuse block [ATTACH type="full" alt="IMG_0306.JPG"]89257._xfImport[/ATTACH] 24 volt trolling motor batteries inside [ATTACH type="full" alt="IMG_0290.JPG"]89251._xfImport[/ATTACH] new 3 bank onboard charger [ATTACH type="full" alt="IMG_0294.JPG"]89252._xfImport[/ATTACH] Some outside shots [ATTACH type="full" alt="IMG_0307.JPG"]89253._xfImport[/ATTACH] [ATTACH type="full" alt="IMG_0308.JPG"]89254._xfImport[/ATTACH] [ATTACH type="full" alt="IMG_0310.JPG"]89255._xfImport[/ATTACH] [ATTACH type="full" alt="IMG_0311.JPG"]89256._xfImport[/ATTACH] [/QUOTE]
2072 SeaArk mods
