Boat House
2nd livewell pump question?
<blockquote data-quote="Weldorthemagnificent" data-source="post: 468371" data-attributes="member: 22139"><p>That's what I was thinking. Bait well probably won't need as much flow as a livewell. I was thinking if you tee off the one pump with a smaller hose, you could supply both with one pump. If it doesn't work, then you can try the second pump. At that time if it's not working how you like, I'd look at either adding a hole or going with a larger one. </p><p></p><p>Sent from my CLT-L04 using Tapatalk</p></blockquote><p></p>
[QUOTE="Weldorthemagnificent, post: 468371, member: 22139"] That's what I was thinking. Bait well probably won't need as much flow as a livewell. I was thinking if you tee off the one pump with a smaller hose, you could supply both with one pump. If it doesn't work, then you can try the second pump. At that time if it's not working how you like, I'd look at either adding a hole or going with a larger one. Sent from my CLT-L04 using Tapatalk [/QUOTE]
Boat House
