Boat House
9.9 HP on TRACKER GRIZZLY 1754 MVX SC
<blockquote data-quote="Stumpalump" data-source="post: 435945" data-attributes="member: 13140"><p>Merc makes a big foot 9.9 with a deeper gear reduction and bigger props. I would think if this is what your getting you could push it along if you matched prop with RPM. That's the exact application that motor was designed for. Fwiw that combo basically reduces prop slip. You will get a ton of prop slip with a regular motor and it will perform as stated earlier.</p></blockquote><p></p>
[QUOTE="Stumpalump, post: 435945, member: 13140"] Merc makes a big foot 9.9 with a deeper gear reduction and bigger props. I would think if this is what your getting you could push it along if you matched prop with RPM. That's the exact application that motor was designed for. Fwiw that combo basically reduces prop slip. You will get a ton of prop slip with a regular motor and it will perform as stated earlier. [/QUOTE]
Boat House
