Alumacraft 14ft f7 floor build
<blockquote data-quote="fishnpreacher" data-source="post: 391210" data-attributes="member: 14497"><p>I have an F7, 1980 model. I have only wired it, mounted rod holders, repaired the transom, and added a foam flooring material from Academy Sports. It is the same flooring that is installed in home gyms.</p><p>I plan on putting a 3/4 plywood floor between the seats and putting the flooring on it. Eventually I would like a front deck/casting platform (same flooring material) and foot controlled trolling motor.</p></blockquote><p></p>
[QUOTE="fishnpreacher, post: 391210, member: 14497"] I have an F7, 1980 model. I have only wired it, mounted rod holders, repaired the transom, and added a foam flooring material from Academy Sports. It is the same flooring that is installed in home gyms. I plan on putting a 3/4 plywood floor between the seats and putting the flooring on it. Eventually I would like a front deck/casting platform (same flooring material) and foot controlled trolling motor. [/QUOTE]
