Boat House
basic live well question
<blockquote data-quote="Ictalurus" data-source="post: 248983" data-attributes="member: 2983"><p>Yes. But as roadkill mentioned, the water level in the livewell will only be equal to it's relative position to the waterline, it wouldn't matter where you put the inlet. Now if your boat drafts 8" - 1' and your livewell is at the bottom of the boat I think that would be fine. However, if your boat drafts 6" or < and the livewell sits off the deck 3", you may need to think about adding a pump and placing an overflow tube in the gravity hole. Hope all that makes sense. #-o</p></blockquote><p></p>
[QUOTE="Ictalurus, post: 248983, member: 2983"] Yes. But as roadkill mentioned, the water level in the livewell will only be equal to it's relative position to the waterline, it wouldn't matter where you put the inlet. Now if your boat drafts 8" - 1' and your livewell is at the bottom of the boat I think that would be fine. However, if your boat drafts 6" or < and the livewell sits off the deck 3", you may need to think about adding a pump and placing an overflow tube in the gravity hole. Hope all that makes sense. #-o [/QUOTE]
Boat House
