Electrical
Basic wiring help needed
<blockquote data-quote="Kimber.45" data-source="post: 194364" data-attributes="member: 3360"><p>I used positive and negative bus bars for my set up with a switch panel. Why is a bus bar for the positive side bad? I havent had any issues with mine. One line from the battery + supplies power to the bus bar, the bar powers my switch panel. One line from the battery - grounds the negative bus bar which grounds everything. The switch panel completes the circuit. I have a terminal fuse block on the battery + with a 50amp fuse that protects the switch panel and a 60amp that protects my trolling motor. Here is a pic of my switch panel with breakers and a pic of what my terminal fuse block looks like.[ATTACH=full]22280[/ATTACH][ATTACH=full]22281[/ATTACH][ATTACH=full]22282[/ATTACH]</p></blockquote><p></p>
[QUOTE="Kimber.45, post: 194364, member: 3360"] I used positive and negative bus bars for my set up with a switch panel. Why is a bus bar for the positive side bad? I havent had any issues with mine. One line from the battery + supplies power to the bus bar, the bar powers my switch panel. One line from the battery - grounds the negative bus bar which grounds everything. The switch panel completes the circuit. I have a terminal fuse block on the battery + with a 50amp fuse that protects the switch panel and a 60amp that protects my trolling motor. Here is a pic of my switch panel with breakers and a pic of what my terminal fuse block looks like.[ATTACH type="full" alt="terminal block.gif"]22280._xfImport[/ATTACH][ATTACH type="full" alt="Switch Panel.JPG"]22281._xfImport[/ATTACH][ATTACH type="full" alt="Switch Panel Wiring.JPG"]22282._xfImport[/ATTACH] [/QUOTE]
Electrical
