Boat House
Boat Keel Leaks
<blockquote data-quote="stinkfoot" data-source="post: 427154" data-attributes="member: 20555"><p>[ATTACH=full]89351[/ATTACH][ATTACH=full]89350[/ATTACH]Goop Coat-it is transparent but a kind of grey-brown colour. It will also wick into the rivets and along the keel from above or below. It is also flexible. I painted this on rather thickly with a roller(two coats and the lines you see are from the slit foam roller.) Used more thinly it is a lot more transparent.</p></blockquote><p></p>
[QUOTE="stinkfoot, post: 427154, member: 20555"] [ATTACH type="full" alt="IMG_20170124_102607.jpg"]89351._xfImport[/ATTACH][ATTACH type="full" alt="IMG_20170124_102620.jpg"]89350._xfImport[/ATTACH]Goop Coat-it is transparent but a kind of grey-brown colour. It will also wick into the rivets and along the keel from above or below. It is also flexible. I painted this on rather thickly with a roller(two coats and the lines you see are from the slit foam roller.) Used more thinly it is a lot more transparent. [/QUOTE]
Boat House
Boat Keel Leaks
