Electrical
Can anyone make me an electrical diagram?
<blockquote data-quote="Oldgeek" data-source="post: 198212" data-attributes="member: 4712"><p>Doc, I made my own busebar for the negative leads from a piece of copper tubing I had laying around. I smashed it flat and drilled 5 holes in it. I ran small machine screws in from the back and then screwed it to a piece of old wood flooring I had. Then I ran all the negative component leads to it and ran one from there to the negative terminal on the battery. It was small enough I mounted the busebar on the bottom of a project box I bought from Radio Shack for $6. I mounted my switch panel in the project box and much to my surprise, everything works. :LOL2: I have fuses on the switch panel for each component.</p></blockquote><p></p>
[QUOTE="Oldgeek, post: 198212, member: 4712"] Doc, I made my own busebar for the negative leads from a piece of copper tubing I had laying around. I smashed it flat and drilled 5 holes in it. I ran small machine screws in from the back and then screwed it to a piece of old wood flooring I had. Then I ran all the negative component leads to it and ran one from there to the negative terminal on the battery. It was small enough I mounted the busebar on the bottom of a project box I bought from Radio Shack for $6. I mounted my switch panel in the project box and much to my surprise, everything works. :LOL2: I have fuses on the switch panel for each component. [/QUOTE]
Electrical
