Trailers
catastrophic tire failure
<blockquote data-quote="Hanr3" data-source="post: 293971" data-attributes="member: 1055"><p>The best option is preventive maintenaince. </p><p> :mrgreen: </p><p></p><p></p><p>Use anti-sieze between the wheel and hub face only. Never use anti-sieze on the lug nuts. The nuts are designed to be used without it, adding the anti-sieze actually weakens the clamping force. Bolt threads are designed to stretch when torqued. Over torqueing and under torquing are both dangerous, hence the torque ratings for lug nuts.</p></blockquote><p></p>
[QUOTE="Hanr3, post: 293971, member: 1055"] The best option is preventive maintenaince. :mrgreen: Use anti-sieze between the wheel and hub face only. Never use anti-sieze on the lug nuts. The nuts are designed to be used without it, adding the anti-sieze actually weakens the clamping force. Bolt threads are designed to stretch when torqued. Over torqueing and under torquing are both dangerous, hence the torque ratings for lug nuts. [/QUOTE]
Trailers
