Jet Boats
General Jet Boat Discussions
Cleat mounting
<blockquote data-quote="jethro" data-source="post: 455063" data-attributes="member: 12381"><p>I didn't even use rivnuts to attach my rod holders and downriggers! Surface welding the cleats to flat aluminum sheet may sound strong, but it's not. You want the cleats through bolted with a backing plate for sure, as it was factory done on my 2100. I actually had to cut access panels in my hull to get the rear rod holders through bolted, but it's done right and done forever.</p></blockquote><p></p>
[QUOTE="jethro, post: 455063, member: 12381"] I didn't even use rivnuts to attach my rod holders and downriggers! Surface welding the cleats to flat aluminum sheet may sound strong, but it's not. You want the cleats through bolted with a backing plate for sure, as it was factory done on my 2100. I actually had to cut access panels in my hull to get the rear rod holders through bolted, but it's done right and done forever. [/QUOTE]
Jet Boats
Cleat mounting
