I have a tracker 185 boat, and upgrading its 2003 graph with a new Helix 5 with DI, SI.
The transducer is bigger than the old one, and before punching anymore holes in the transom (5 holes already for previous/current transducers), I was hoping someone has already installed a humminbird with SI on a tracker... to see where they mounted it.
I would like to get depth readings at faster speeds if possible (that I don't get today) and of course, like to get the SI working, so the motor being in the way may be a problem.
You can see the old location holes in this shot and see it's stepped and there is a rail next to the bunker board that would likely interfere at faster speeds
Side shot so you can see the spacing available and how the motor will likely get in the way for SI when it's trimmed in.
Just another shot so you can see how the existing transducer is attached. I don't get high-speed depth readings (20+MPH)
