Trailers
Help with trailer lights
<blockquote data-quote="KMixson" data-source="post: 380261" data-attributes="member: 432"><p>Bad grounds can cause some strange problems. Things that should not be possible are possible with a bad ground. Do your windshield wipers turn on when you turn your left turn signal on, bad ground. Does your horn blow when you turn your right turn signal on, bad ground. Do your head lights flash Morse code when you turn off the radio, bad ground. I have seen some very strange things with a bad grounds.</p></blockquote><p></p>
[QUOTE="KMixson, post: 380261, member: 432"] Bad grounds can cause some strange problems. Things that should not be possible are possible with a bad ground. Do your windshield wipers turn on when you turn your left turn signal on, bad ground. Does your horn blow when you turn your right turn signal on, bad ground. Do your head lights flash Morse code when you turn off the radio, bad ground. I have seen some very strange things with a bad grounds. [/QUOTE]
Trailers
