Boat House
How bad is this corrosion?
<blockquote data-quote="PSG-1" data-source="post: 353403" data-attributes="member: 6937"><p>Not by him....LOL Or, if you do have it welded by that welder again, you need to advise him of the ABYC and AWS standards for welding aluminum in marine environments, and which alloys are acceptable, which are not.</p><p></p><p>In any case, that bad spot will need to be drilled/ground out, then re-welded with the correct filler wire. That would be my assessment.</p></blockquote><p></p>
[QUOTE="PSG-1, post: 353403, member: 6937"] Not by him....LOL Or, if you do have it welded by that welder again, you need to advise him of the ABYC and AWS standards for welding aluminum in marine environments, and which alloys are acceptable, which are not. In any case, that bad spot will need to be drilled/ground out, then re-welded with the correct filler wire. That would be my assessment. [/QUOTE]
Boat House
