Boat House
Installing a bilge pump?
<blockquote data-quote="Jim311" data-source="post: 367508" data-attributes="member: 15289"><p>On small boats I like to mount it on the left or right side as close to the transom as possible. The reason I like it this way is because it's often difficult to get all the water out of the hull. So I stand as close to the transom as possible, and lean to the left or the right (whichever side the bilge pump is on) and all the water in the hull runs to that side, where it is then pumped out. It just helps completely pump out the hull so you aren't standing in a fraction of an inch of water.</p></blockquote><p></p>
[QUOTE="Jim311, post: 367508, member: 15289"] On small boats I like to mount it on the left or right side as close to the transom as possible. The reason I like it this way is because it's often difficult to get all the water out of the hull. So I stand as close to the transom as possible, and lean to the left or the right (whichever side the bilge pump is on) and all the water in the hull runs to that side, where it is then pumped out. It just helps completely pump out the hull so you aren't standing in a fraction of an inch of water. [/QUOTE]
Boat House
