Motors
Is this a shift AND throttle control box?
<blockquote data-quote="fatherfire89" data-source="post: 205485" data-attributes="member: 4679"><p>Got this with my motor. Does the main lever control both throttle and shift? There is also a little black lever that seats into control box and I'm not sure what its for. Thanks.</p><p></p><p>ADDITION: So I got my new cables hooked up. When I move the main lever one cable moves and when I move the smaller black lever the other cable moves (only about 1.25"). So is there some sort of electronic signal between the throttle under the hood of the motor and the control box? I dont understand how the motor will accelerate and shift if the main lever on the control box only moves one of the two cables coming out of the box.</p></blockquote><p></p>
[QUOTE="fatherfire89, post: 205485, member: 4679"] Got this with my motor. Does the main lever control both throttle and shift? There is also a little black lever that seats into control box and I'm not sure what its for. Thanks. ADDITION: So I got my new cables hooked up. When I move the main lever one cable moves and when I move the smaller black lever the other cable moves (only about 1.25"). So is there some sort of electronic signal between the throttle under the hood of the motor and the control box? I dont understand how the motor will accelerate and shift if the main lever on the control box only moves one of the two cables coming out of the box. [/QUOTE]
Motors
