Loweline 1436 Refurb. Need advice from the experienced.
<blockquote data-quote="Johnny" data-source="post: 424910" data-attributes="member: 13599"><p>Dan, if you want to use the Z-bar brace, that will be fine.</p><p>looking at it, I also thought it was pretty thin metal.</p><p>to make a bracket that you want, weld a piece of flat bar</p><p>to the edge of a piece of angle aluminum.</p><p>The new wood will determine the open area of the Z-Bar.........</p><p>so if you want to go this route, make your new transom first</p><p>then fabricate the Z-Bar to fit your wood thickness.</p><p>of course you can use your choice of thickness aluminum: 1/8", 3/16" or 1/4".</p><p></p><p></p><p>jus my Dos Centavos</p></blockquote><p></p>
[QUOTE="Johnny, post: 424910, member: 13599"] Dan, if you want to use the Z-bar brace, that will be fine. looking at it, I also thought it was pretty thin metal. to make a bracket that you want, weld a piece of flat bar to the edge of a piece of angle aluminum. The new wood will determine the open area of the Z-Bar......... so if you want to go this route, make your new transom first then fabricate the Z-Bar to fit your wood thickness. of course you can use your choice of thickness aluminum: 1/8", 3/16" or 1/4". jus my Dos Centavos [/QUOTE]
