Motors
Lower Unit still leaking after replacing seals
<blockquote data-quote="Pappy" data-source="post: 211513" data-attributes="member: 3278"><p>The O-Ring that looked too small is actually the shift shaft O-ring (which you apparently did not replace). Aside from the propshaft seal that is the most common cause of a leak in the old gearcases. The brass bushing has to be driven out and the o-ring can be replaced. Takes a special tool (driver) to do it properly. Go to https://www.aomci.org. then to the ask-a-member section and look up Frank Robb and have him send you a tool. They are inexpensive.</p></blockquote><p></p>
[QUOTE="Pappy, post: 211513, member: 3278"] The O-Ring that looked too small is actually the shift shaft O-ring (which you apparently did not replace). Aside from the propshaft seal that is the most common cause of a leak in the old gearcases. The brass bushing has to be driven out and the o-ring can be replaced. Takes a special tool (driver) to do it properly. Go to https://www.aomci.org. then to the ask-a-member section and look up Frank Robb and have him send you a tool. They are inexpensive. [/QUOTE]
Motors
