Motors
Make sure its pumping water
<blockquote data-quote="Quackrstackr" data-source="post: 194880" data-attributes="member: 437"><p>That all depends on where the pisser is plumbed into, before or after going through the head.</p><p></p><p>My 2008 90hp doesn't start until the thermostat opens. It takes it a while to get going when the temps are cold (but still above freezing).</p><p></p><p>They should all be plumbed to whiz after going through the head (although most aren't unless you do it yourself) that way you know that your water pump is working <u>and</u> that you don't have a blockage in the thermostat or head. There are a lot of guys that have burned their motors up in the winter from ice blockage while the pisser hose was shooting water like no tomorrow.</p></blockquote><p></p>
[QUOTE="Quackrstackr, post: 194880, member: 437"] That all depends on where the pisser is plumbed into, before or after going through the head. My 2008 90hp doesn't start until the thermostat opens. It takes it a while to get going when the temps are cold (but still above freezing). They should all be plumbed to whiz after going through the head (although most aren't unless you do it yourself) that way you know that your water pump is working [u]and[/u] that you don't have a blockage in the thermostat or head. There are a lot of guys that have burned their motors up in the winter from ice blockage while the pisser hose was shooting water like no tomorrow. [/QUOTE]
Motors
