- Joined
- Jan 31, 2024
- Messages
- 21
- Reaction score
- 14
- LOCATION
- ST GEORGE, UTAH
What is the cable gauge for the cables to the cranking battery?
Thanks Pappy, I'm going to put the cranking battery in the bow storage & use 6 gauge tinned copper.Factory cables are probably around 6ga or so. If making your own it never hurts to go to a larger ga. as it carries the electrical load better. Those little electrons only run on the outside of a conductor so the more wires and gauge size the better!
There are many charts out there for 12V load vs. wire ga. when wiring a boat. When measuring always measure the complete circuit not just one way. If in doubt always go to the larger size cable.
If you run in any chop or rough seas, you could damage your battery. Batteries don' t like harsh jostling, one reason they are not often found in front. Just some food for thought !!Thanks Pappy, I'm going to put the cranking battery in the bow storage & use 6 gauge tinned copper.
That is well understood, battery in a box with foam padding strapped down. Chop is a slow zone for me.If you run in any chop or rough seas, you could damage your battery. Batteries don' t like harsh jostling, one reason they are not often found in front. Just some food for thought !!
