Boat House
Mid 90's Bass Tracker
<blockquote data-quote="MrSimon" data-source="post: 215432" data-attributes="member: 5461"><p>Just like the others said, its plywood decking over aluminum bracing.</p><p></p><p>If the boat is older, there is a good chance the plywood is rotted, wet, or both .... which means it weighs a ton. Its pretty easy to tear up the wood. This is what you'll find. Putting down new wood, or even sheet aluminum is pretty easy too.</p><p></p><p><img src="https://lh3.googleusercontent.com/-Ivcvu639Yas/Tba0TuxKuhI/AAAAAAAANhQ/grUVjpZOhzw/s800/IMG_1576.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p></blockquote><p></p>
[QUOTE="MrSimon, post: 215432, member: 5461"] Just like the others said, its plywood decking over aluminum bracing. If the boat is older, there is a good chance the plywood is rotted, wet, or both .... which means it weighs a ton. Its pretty easy to tear up the wood. This is what you'll find. Putting down new wood, or even sheet aluminum is pretty easy too. [img]https://lh3.googleusercontent.com/-Ivcvu639Yas/Tba0TuxKuhI/AAAAAAAANhQ/grUVjpZOhzw/s800/IMG_1576.jpg[/img] [/QUOTE]
Boat House
