Boat House
Modifying Grizzly 1448 Transom
<blockquote data-quote="nccatfisher" data-source="post: 450163" data-attributes="member: 10811"><p>I have the same boat, I am running a 5" setback on mine and the cavitation plate is almost 3" above the bottom of the boat at startoff with no blowout. I could run it higher once planed but would be scared of it starving for water and running hot quit frankly. I have trimmed it up higher a couple of times just to check and it would come up considerably but I don't see the need most of the time. I have pulled it up when I was easing around in extremely shallow water and I could keep an eye on the indicator stream to make sure I wasn't starving it.</p></blockquote><p></p>
[QUOTE="nccatfisher, post: 450163, member: 10811"] I have the same boat, I am running a 5" setback on mine and the cavitation plate is almost 3" above the bottom of the boat at startoff with no blowout. I could run it higher once planed but would be scared of it starving for water and running hot quit frankly. I have trimmed it up higher a couple of times just to check and it would come up considerably but I don't see the need most of the time. I have pulled it up when I was easing around in extremely shallow water and I could keep an eye on the indicator stream to make sure I wasn't starving it. [/QUOTE]
Boat House
