Motors
Motor mounting question
<blockquote data-quote="richg99" data-source="post: 195536" data-attributes="member: 4376"><p>roltide....you know...I thought further about your query and my earlier response. </p><p></p><p>While, in a perfect world, your cav plate would be dead even with the bottom of the boat.....I guess I'd give it a try as is. </p><p></p><p>If you are like me, you hardly ever run the engine WOT. so, if you lost a little efficiency due to the mistaken height....it still is not a big deal. </p><p></p><p>Try it and then make your decision. regards, Rich</p><p>--------------</p><p></p><p>mtnwrkr I'd go with the largest bottom surface area as your guide,,,,, that means that the little "keel" would not be an issue. Just my opinion...what do I know?... ha Rich</p></blockquote><p></p>
[QUOTE="richg99, post: 195536, member: 4376"] roltide....you know...I thought further about your query and my earlier response. While, in a perfect world, your cav plate would be dead even with the bottom of the boat.....I guess I'd give it a try as is. If you are like me, you hardly ever run the engine WOT. so, if you lost a little efficiency due to the mistaken height....it still is not a big deal. Try it and then make your decision. regards, Rich -------------- mtnwrkr I'd go with the largest bottom surface area as your guide,,,,, that means that the little "keel" would not be an issue. Just my opinion...what do I know?... ha Rich [/QUOTE]
Motors
