Electrical
MotorGuide HVT-3600 36lb Thrust
<blockquote data-quote="FuzzyGrub" data-source="post: 255775" data-attributes="member: 3438"><p>I have had one for a number of years and still runs fine. A standard 5 Forward, 2 reverse speeds, transom mount. It takes the more common larger diameter props. </p><p></p><p>It is a metal shaft, and would not recommend for a reverse mount on a bow, in case you were thinking of that.</p><p></p><p></p><p>Correction: Just checked, I have the HVT3700. I beleive the only difference is 1lb of thrust.</p></blockquote><p></p>
[QUOTE="FuzzyGrub, post: 255775, member: 3438"] I have had one for a number of years and still runs fine. A standard 5 Forward, 2 reverse speeds, transom mount. It takes the more common larger diameter props. It is a metal shaft, and would not recommend for a reverse mount on a bow, in case you were thinking of that. Correction: Just checked, I have the HVT3700. I beleive the only difference is 1lb of thrust. [/QUOTE]
Electrical
