Motors
oil/fuel ratio
<blockquote data-quote="Pappy" data-source="post: 205303" data-attributes="member: 3278"><p>there may be a button on the end of your throttle handle that you simply have to push in to shut it down. Also if there is an idle adjustment knob at the end of the throttle handle you can turn it counter clockwise and lower the idle timing to the point it will shut down when the handle is returned all the way to idle.</p></blockquote><p></p>
[QUOTE="Pappy, post: 205303, member: 3278"] there may be a button on the end of your throttle handle that you simply have to push in to shut it down. Also if there is an idle adjustment knob at the end of the throttle handle you can turn it counter clockwise and lower the idle timing to the point it will shut down when the handle is returned all the way to idle. [/QUOTE]
Motors
oil/fuel ratio
