rivets 14' Mon Ark rebuild
<blockquote data-quote="panFried" data-source="post: 281500" data-attributes="member: 9467"><p>mtydg, I'm going with both Solid Aluminum rivets and Stainless Steel bolts and 2 tubes of 3M 5200 for good measure. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" /> I believe it depends on comfort level and location of bad rivets. Some of mine are on the bottom of the boat, so ill use rivets there. Transom, Ill use bolts and 5200 with a dab of loctite (red). Hope that helps and check out many of the other posts. Lots of transom replacements going on.</p></blockquote><p></p>
[QUOTE="panFried, post: 281500, member: 9467"] mtydg, I'm going with both Solid Aluminum rivets and Stainless Steel bolts and 2 tubes of 3M 5200 for good measure. :D I believe it depends on comfort level and location of bad rivets. Some of mine are on the bottom of the boat, so ill use rivets there. Transom, Ill use bolts and 5200 with a dab of loctite (red). Hope that helps and check out many of the other posts. Lots of transom replacements going on. [/QUOTE]
