Boat House
Side console to CC throttle question
<blockquote data-quote="DaleH" data-source="post: 441362" data-attributes="member: 15636"><p>Given those constraints, get a new or used BINNACLE mount control.Your cables will go down through the console (out of sight and out of UV exposure) into the bilge, along or between your cross-hull bulkhead to get to the starboard gunnel, then routed as normal back to the motor. </p><p></p><p>Be sure to add a conduit run for electrical & harness, or route the control cables w/ the harness. Tie in a permanent "pull" (coiled stiff mono, etc.) for future electrical additions. See here for more:</p><p>https://www.forum.tinboats.net/viewtopic.php?f=3&t=36661&hilit=Coil</p></blockquote><p></p>
[QUOTE="DaleH, post: 441362, member: 15636"] Given those constraints, get a new or used BINNACLE mount control.Your cables will go down through the console (out of sight and out of UV exposure) into the bilge, along or between your cross-hull bulkhead to get to the starboard gunnel, then routed as normal back to the motor. Be sure to add a conduit run for electrical & harness, or route the control cables w/ the harness. Tie in a permanent "pull" (coiled stiff mono, etc.) for future electrical additions. See here for more: https://www.forum.tinboats.net/viewtopic.php?f=3&t=36661&hilit=Coil [/QUOTE]
Boat House
