Boat House
Steelflex
<blockquote data-quote="Brine" data-source="post: 118588" data-attributes="member: 1053"><p>I'd make sure your electrical system isn't a source of your corrosion. If all of your corrosion is below the waterline, I would think Steelflex may be a good option for you applied to the outside of the boat. I don't see the value in applying anything on the inside if the corrosion is coming from the outside, but I don't fully understand the intracacies of tin boats and salt water either.</p></blockquote><p></p>
[QUOTE="Brine, post: 118588, member: 1053"] I'd make sure your electrical system isn't a source of your corrosion. If all of your corrosion is below the waterline, I would think Steelflex may be a good option for you applied to the outside of the boat. I don't see the value in applying anything on the inside if the corrosion is coming from the outside, but I don't fully understand the intracacies of tin boats and salt water either. [/QUOTE]
Boat House
Steelflex
