Boat House
STUCK Seat pedestal! help
<blockquote data-quote="redbug" data-source="post: 350166" data-attributes="member: 71"><p>so it looks like it is a threaded base... you can spray some penetrating oil on the bottom and let it sit then add more oil if given time it will work also take your pipe wrench and a hammer and hit the wrench so that it tightens the post then hit the other way to loosen it that will work about 75% of the time the key s penetrating oil wd40 may not cut the rust</p></blockquote><p></p>
[QUOTE="redbug, post: 350166, member: 71"] so it looks like it is a threaded base... you can spray some penetrating oil on the bottom and let it sit then add more oil if given time it will work also take your pipe wrench and a hammer and hit the wrench so that it tightens the post then hit the other way to loosen it that will work about 75% of the time the key s penetrating oil wd40 may not cut the rust [/QUOTE]
Boat House
